Protect error cant get the amp to work, has "protect" displayed on screen and nothing seems to work, pls help!!!
    Champion:
  • 211 Answers
If your amplifier goes into the protection, there's really something wrong. There are different kind of protections but usually that circuit does see a DC voltage on your speakeroutput.
So it's a protection for your speakers.
regards,
Gerard
Posted on Jan 31, 2009
Nad av 716 protect
If your NAD amplifier is in protect mode with no speakers connected, it will be necessary to open it up and check for internal component failure.
Jan 05, 2015 | NAD Audio Players & Recorders
Power protect
is' protect 'appears on display?.remove speakers & check again.if then set work without error check speakers & cable. protect appears again there is a problem with power amp module.
Jun 14, 2011 | Sony MHC-RG40 CD Shelf System
Trying to hook up sony s-master with componet cables an the s-master displays on the display ''PROTECT UNPLUG'' however with nothing plugged in the s-master, works fine
Check speaker wires, any wire seems shorted and causing Protect Unplug error message in receiver.
Good way to sort out bad wire is plug one speaker at a time, turn On receiver check, turn Off, then plug next speaker wire until you find out what speaker wire activates protection circuit of receiver.
Thanks.
Jan 01, 2011 | Audio Players & Recorders
Amp pulses from power to protect
check it without the speakers if they go to protection,and if not check the speakers
May 27, 2010 | Power Acoustik PS4-800 Car Audio Amplifier
When ever i turn on my engine which means my kenwood kdc237 shud come on its just flashing protect protect protect no matter wot i press nothig happens need help cant do without music.
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Jan 20, 2010 | Kenwood KDC237SA CD Player
Message displays push power protect, pls help
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a lost contact.First try to resolder the pins of STK-IC if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Jun 08, 2009 | Audio Players & Recorders
My boombox is displaying the word "Protect" in the display. ???
The protect message indicates that there is a problem with the final stage of the amplifier section. This unit will require repair as a reset will not clear this. There is an audio amp IC inside that needs to be replaced. Figure on about $15 or so for the part.
Dan
Dec 09, 2008 | Sony Boom Box With CD Player & Cassette...
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
My audio system says protect on display
Hi Jean,
Without a brand and a model, best that I can provide are generic possibilities:
1. unplug the unit from the mains for a couple of hours. This is supposedly to reset most systems; and/or
2. check the speaker wires and make sure none of any bare wires are touching each other.
If your concern has not been corrected after completion of the above procedures, pls post back brand and model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Audio Players & Recorders
264 people viewed this question
 Grubhead
Grubhead
