Question about LG WM2277H Front Load Washer
LG WM2277H - OE error
I keep getting the OE error even after draining, cleaning the filter and even resetting the machine. Is there anyway of getting the front of and looking to see if there's an internal clog or checking the pump?
  • Anonymous Mar 22, 2014
    My drain discharge has to go a "sump pump" that pumps the discharge where it needs to go. My problem is that the discharge clogged up the sump pump with lint and "gunk" according to the plumber who unclogged the sump pump. In less than a year, the pump is clogged again. In that time I've periodically checked and cleaned the drain pump filter but it has hardly needed any cleaning at all. Is there something besides the drain pump filter that should prevent lint and "gunk" from clogging up my sump pump?
THE ABOVE SOLUTION WORKED LIKE A CHARM. IT WAS A TINY BONE STUCK IN THE PROPELLER BLADES. THANKS FOR THE SOLUTION!!!!!!!!
Posted on Jun 20, 2008
Yes,once you have disconected the power supply.open the filter hatch then undo the screw,this willennable you to remove the bottom plinth,unscrew the three screws that hold housing of pump,remove both the circ pump and the drain ,u will find offending item there
Posted on Jul 30, 2007
SOURCE:
LG WM2277H front load washer isn't draining.
there is a clog somewhere in the drain for sure see the link below
if you think it has been cleared unplugg for 10 minutes and see what happens LG Front Load Washing Machine Error Code OE How To Clear
steer clear of LG as a repairman for a living they have weird problems like this all the time
over computerized with lo grade parts inside from my experiences
Feb 03, 2018 | LG WM2277H Front Load Washer
Filter clean drain hose straight and only 12" high still get OE code
Check for an obstruction in the pump itself. Post back the results.
Jan 21, 2013 | LG WM2277H Front Load Washer
I"m getting the OE signal.
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 12, 2011 | LG WM2277H Front Load Washer
My washer has stopped it still has water and soap in it OE is flashing on the screen
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Apr 05, 2011 | LG WM2277H Front Load Washer
"OE" error. Filter cleaned but makes terrible
You still have something caught in the drain line on the machine. Check the filter again and the lines coming from the tub to the pump, and from the pump to the waste line. Here is a link to LG's document on the "OE" error.
Jan 10, 2011 | LG WM2277H Front Load Washer
How do i clean the drain screen? and where is it? It won't drain and has a OE flashing.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | LG WM2277H Front Load Washer
Gives message...oe
On pg 18 of the service manual for this combo, front-load LG washer/dryer, it basically says if the drain's not working and you see an OE error code, clean the drain pump filter and retry. So first do that.
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
Manual above.Below is a great DIY self help washer site, use with manual to sort your problem out.
http://www.washerhelp.co.uk/diy-repair-help.html
Jun 18, 2010 | LG WM-2277HW Front Load Washer
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
LG WM2233H* Clogged drain
After draining and cleaning filter, reset washer--Unplug unit and hold Start (selector) button for 10 seconds. Plug unit in and restart.
Oct 28, 2008 | LG WM2277H Front Load Washer
LG WM2277H Front Load Washer Logo
433 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
