Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
Printer sharing wirh USB hub
I have two systems with Vista. I want to Use one printer on both with USB Cables. Can i connect a USB Hub with 3 ports, 2 for two systems and one for Printer and I install drivers on the both systems. Is this possible. I found differnet USB switches on net but they should have to select first the system from which the print is required.
    Problem Solver:
  • 10 Answers
I would connect the printer to the main computer, network the 2 computers and enable printer sharing. The only draw back to this is that the main computer will have to be on in order for the other to print. Vista makes this easy to do.
Posted on Mar 11, 2009
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
I purchased a DYNEX USB 2.0 Port Hub last week. I have 2 computers and want to have both of them hooked up to the same printer. I purchased 2 A >A USB cables and the printer is still not working. I...
in either computer have you set the printer to default so that each computer knows where to send the data
you may also have to have the computers on a home network for it to work
the hub by itself is not the answer
Jun 03, 2017 | Dynex 4-Port USB 2.0 Hub
How to configure 4 Lan + 1 Printer +internet connections
If all your connections are wired, you can use one of the three following solutions.
1. Purchase a router with more then 4 LAN ports on it.
2. If the printer or any of the computers have a wireless network card, then purchase a wireless router and simply connect 4 LAN cables and 1 WLAN.
3. Purchase a hub. Connect 3 computers to the first 3 LAN ports on the router; connect the hub to the fourth LAN port and then connect the last computer and the printer to the hub. In essence both your computer and the printer will share the same IP address (the IP given to the hub) and they should work.
In any of these situations, connect the internet connection to the WAN port of your router.
Thanks,
Pat
Apr 02, 2010 | ASUS RT-N13U IEEE 802.3/3u IEEE 802.11b/g...
Chronic message "No Hp Devices Detected"yankedo on Apr 20, 2009" " Have to constantly uninstall and reinstall printer for it to function. Sometimes only lose the scanner function, other times all...
Are you using the ethernet connection or a USB connection? If you are using USB, do you have the printer connected to a hub or directly to the computer? Does changing the cable to a different USB port get the computer to see the printer? If you are using a USB port in a hub, try a direct connection. Does the USB hub have power-transformer or is it powered by the computer? Printers are extremely sensitive to losing data when the cable run is too long or the USB hub has too many devices attached (particularly when powered by the computer). Also try a new USB cable. An additional troubleshooting test: turn off your printer for 30 seconds, unplug both sides of the USB cable and see if it is found when you plug it back in and turn it on.
If you are using an ethernet connection, check the cables for both the printer and the computer. Also try plugging the cables into different ports on your router or switch. I'm assuming you have your network working and have a IP address (if your network gives dynamic addresses). You might try repairing the network connection (right click on the network icon in the system tray in XP or Vista).
If these ideas do not help, I'm not sure what is causing your problem.. I hope this helps.
Sep 19, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can I share 1 printer with 2 computers 1 Vista 1 XP with the hub?
Yes you can share out one printer from 2 computers. you can either set up a home network using arouter to connect your 2 computers. Or you can use an a /b switch to share the printer.
Nov 21, 2008 | Belkin BLKF5U201 USB Peripheral...
I need to know what connections i need to connect two computers to one hp printer
A 5 port switch (Hub) and network cables are about the simplest.
If the printer doesn't have a network port, you can add a small print server.
The print server is a little device the connect to the parallel port on the printer.
You then connect it to one of the ports on the switch (Hub)
Another way to share a printer is to connect the printer to one of the computers, and then share it. This is considering that you have the 2 computers networked together.
The drawback with this setup vs the first one, is that the computer that has the printer attached, must be on for the other computer to be able to print to it. The first setup, you only need to have the printer on, for either computer to be able to print to it.
Aug 16, 2008 | HP Office Equipment & Supplies
Printer doesn't seem to like my 7 port USB hub
Hi Bob,
A lot of the time devices plugged into a USB hub don't receive enough power to run correctly. One possible solution is to get a dual-input usb cable and try using that. These cables connect to a usb device and then have two jacks for plugging into ports, which may supply enough power. You should be able to find them online fairly cheaply, so if you can spare 2 spots in the usb hub that may be your best bet.
Feb 14, 2008 | HP LaserJet 2200 Printer
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
285 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
