Question about Teac MCD-85 CD Shelf System
Can't do anything - LCD screen says "PROTECT"
Within 60 seconds of turning on my stereo system, the LCD screen pops up with "PROTECT" and everything shuts off. This happens when I try to listen to the radio, play a CD or use the auxillary cord for my iPod. Any suggestions?
  • 3 Answers
It may be that there is a problem with a fuse inside the stereo. It may say protect because the fuse has broken a connection that allows it to turn on. If the protect goe sup it is trying to help save the stereo from cooking its self, and give you a chance to get it fixed. If that is not the problem then it may be easier to just buy a new one, because a fix may be expensive if you don't have any warranties.
Posted on Jul 14, 2008
SOURCE:
Everything is zoomed in
My E19T6W 19" LCD monitor has a menu that keeps popping up on the bottom right corner of
my screen. Has been doing this continually since I got it. Changes from the eMachine monitor tour to resolution and contrast menus. I keep turning it off and within seconds it'll be right back. For the most part I just ignore it, but recently it has been driving me insane during movies.
Aug 29, 2011 | eMachines E19T6W 19" Monitor
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
My stereo won't work. Whenever I try to turn it on, it always turns off saying "protect." How can I fix this?
The protect has come on because it senses an output load problem, Turn the unit off, unhook the speakers and wires from the stereo, now turn the unit on and turn the volume down as far as it will go, this should reset the processor ic, if the word protect stays off you have a short in the wiring or bad speaker. If the protect comes back on with everything unhooked the problem is in the audio output ic pack in the stereo and will require a technician to remedy.
Jan 17, 2011 | JVC MX-KC58 Shelf System
Had my Tv for a week and connected it to a Thomson sky receiver. Everything worked fine until today. When watching sky progammes the screen continuously flashes every second making viewing impossible. I've...
Make sure both deviced are set for 60 htz, it might be that there is a signal overly if one is set for 50 htz and one for 60 htz double check your screens refresh rate make sure its 60 htz as well. If it flashes once every second while staying on most of the second this could be it. check to also make sure all the cords are correctly positioned and try to keep the cords away from audio equipment stereos/ home audio, this can also cause signal issues.
Nov 06, 2010 | LG 42LC2D 42 in. LCD HDTV
PROTECT MODe
reed the users manual...does it say anything about the protect mode ?
Aug 13, 2009 | JVC HX-D7 Shelf System
PROTECT mode
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>> [email protected]
Jul 17, 2008 | Sharp CD-C2900 Shelf System
Protect screen on my sharp cd-ba150
that is your movement protection. In your manual it says how to get rid of it. mostelikely you have to push power and open button at same time
Jul 08, 2008 | Sharp CD-C662 Shelf System
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Sony 60 cd changer mhc-gs300av
The audio amplifier IC is damaged and need to be replaced
Nov 21, 2007 | Sony MHC-GS300AV CD Shelf System
Sharp Stereo- Protect Mode??
Try plugging in a pair of headphones. I tried it without the speakers connected and since it found the headphones and they were OK the system came out of protect mode.
Nov 21, 2007 | Kenwood XD-655 CD Shelf System
Teac MCD-85 CD Shelf System Logo
533 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
