Averatec 4100 series white line on screen
I've had this laptop for a few years already; I usually don't use it that much. I have a small vertical white line down the center of the screen. What can I do to fix this issue or maybe a way to diagnose it correctly?
What usually causes this; can it be that I left it in the sun, left items on top of it when not in use... what?
    Problem Solver:
  • 3 Answers
Okay go to: Flexcode.org/lcd.html
Once there select toggle full screen, then try 2nd method. Click on ( go full screen now) Let this run for 30mins. to an hour. Keep on full screen.
Your labtop screen pixel can be stuck on that color. This should help it go back to normal. If not, I have another method. Try this one out first.
*NOTE* Do not try the Pressure Method or Tapping Method.
Posted on Feb 26, 2009
HP Pavilion DC6, Radeon Graphics card. How do I adjust contrast?
Start / Control Panel / Display / Settings / Advanced / Graphics Media Accelerator / Graphics Properties / Schemes
lots of clicks! This should get you what you want. You'll probably have to experiment with settings a little to get what is truly comfortable to you.
If this is helpful, please take a sec to rate me. Thanks!
Don
Mar 16, 2012 | HP Pavilion dv6000z Notebook
A vertical white line appears on my screen
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical white line. Usually screen replacement is the only answer to fix it.
Feb 17, 2011 | Acer Aspire 4315 Notebook
Need drivers for averatec 4200 series
Click here; http://www.trigem.com/us/support/drivers.asp and download 4100 series, am sure you will be helped out.
Rgds
Feb 15, 2011 | Averatec 4200 Notebook
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 10, 2011 | IBM ThinkPad R52 Notebook
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
White vertical line through laptop screen
The cause is a failure of the LCD, and you can fix it by replacing the LCD.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+5160+LCD&_sacat=See-All-Categories
Instructions are here
http://support.dell.com/support/edocs/SYSTEMS/ins5160/en/SM/display.htm#wp1105699
Mar 29, 2010 | Compaq Presario M2000 Notebook
Hello today I had an white vertical line in the center of my PC screen Gateway E2500s series would not shut down from the tower so IV turned it off with the surge and waited a few them turned it back on...
You mention in your post to branded laptops. You can try to check if the problem is from the LCD or from the Video card. Connect your laptop to an external monitor and check if the white vertical line appears, if yes replace motherboard if video card is integrated, if expansion then replace video card alone. If no lines from the external monitor then laptop LCD has the problem.
Oct 03, 2009 | Dell Latitude D505 Notebook
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
