Question about Zanussi IZ12 Front Load Washer
Washiing machine will not spin.
Machine goes through cycle but will not spin
  • Anonymous Feb 28, 2009
    i have the same problem have cleaned out pump but still won't spin
    Problem Solver:
  • 16 Answers
Check outlet pump.Clean and try again.Jan
Posted on Feb 15, 2009
My Kelvinator K600 Washing Machine sometimes does not operate on the Spin Cycle
Spin clutch soliniod not engageing underneath (replace).
Oct 02, 2016 | Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Washer completes cycle 100% but then it restarts and starts filling all over again/ rewashes in essence
Dear William, I guess first you have to check if the start switch is shorted. When you turn on the machine, does it automatically go into cycle? If yes, then your start switch is faulty. Otherwise, you may have to replace your timer/sequencer.
Jan 16, 2014 | Washing Machines
I have a hotpoint WMA63. It goes through the washing cycle, and the water drains but when the spin cycle starts, the 'spin' light just flashes continuously. The drum goes around fine during the...
Hi, My guess is that you have an uneven load in machine. When it's time for the spin cycle to run, it will not complete that spin. You will have to open the door and rearrange the load so that it will spin.( machine will not run when door is open). good luck.
Jun 08, 2011 | Washing Machines
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
Mechein washis but will not spin
There is a possibility that the load was out of balance.or open the door and redistribute the clothes before trying again. You could try taking the washing out and putting the washing machine back onto a spin program. If it seems to spin OK now, it could be that the load was not balanced properly.
Sep 15, 2008 | Washing Machines
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Servis washing machine
the bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Zanussi IZ12 Front Load Washer Logo
108 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
