Question about Olympus EVOLT E-300 Digital Camera
Card Eject Button Not Working
When I try to insert the memory card in, the eject button will not lock in - it pops out to the open position. When the eject button is in this position, the card bay door will not close preventing the camera from operating. After much fiddling around with the card and eject button, I am on occasion able to get the card inserted properly with the button in the down position. Conversely when the card and button are both properly in place, the eject button will not work to eject the card. Again, after much fiddling around I am usually able to get the card and button back in "sync". This happens every time I go to insert or eject a card. I shipped the camera to the Olympus repair facility only to be told they have a flat repair rate for the E-300 (regardless of what the problem is)of $257 and change. I'm having them ship the camera back not repaired. Any suggestions would be welcome.
    Genius:
  • 2,985 Answers
I hgave the came camera it does take two pushes to get it to lock down - just a quirk I guess
Posted on Sep 04, 2007
I got cannon power shot sx130 is it reads memory card error the memory card is not locked but the eject button is not working how to fix this problem. thanks
Try to switch off the Camera and restart it gain. Again, Sometimes, its due to some auto-run software running in the card which prevents that from ejection. You can try to even format the card in the camera itself. That may work also.
As a last resort, check up your camera and get that memory card removed out of your Camera.
Feb 16, 2015 | Canon Powershot SX130IS Black Digital...
How do I remove the memory card
Using a fingertip, push down on the edge of the card as if to insert it further into the slot. The card will pop out a fraction, and you can grasp it between your fingertips and pull it out.
Jul 13, 2012 | Vivitar ViviCam Cameras
How to remove protection on memory card on a 3310 mobile
  1. Remove the card from your cell phone by pushing the card into the phone and then releasing it. The card will "pop" up from its slot. Pinch the card between two fingers and pull it out of the phone.
  2. Hold the card so the card label is facing you.
  3. Push the sliding lever on the upper left side of the card up, toward the top of the card. This will unlock the write protection on the card.
  4. Mini and Micro SD Cards
  5. Remove the card from your cell phone by pushing the card into the phone and then releasing it. The card will "pop" up from its slot. Pinch the card between two fingers and pull it out of the phone.
  6. Insert the card into a card reader (this will allow it to be read as a normal-sized SD card). Make sure that if the card reader has a slide lever on the upper right-hand side, it is in the "unlocked" position. That position will be marked directly on the reader.
  7. Insert the reader into your computer.
  8. Open the command prompt on your computer. For Windows users, this is an "Open" that will appear when you click on the "Start" button. For MAC users, open the "Finder" window and click on the drive and then select "Get Info."
  9. View the permissions for the drive. Windows users will need to type "reg edit" after the "Run" prompt. MAC users need only click on the "Ownership and Permissions" choice in the Info window.
  10. Reset the permissions for the phone memory card. Windows users need to make sure that the value in the permissions window is set to "0." MAC users will need to click on the appropriate box to select "Read & Write." Save your changes and exit the Info or Regedit programs. Follow your normal steps for your operating system to eject the card reader and then eject the memory card from the reader and reinstall it in your phone.
  11. please drop your comment and rate about this post.raise the thumb up
Dec 21, 2010 | Health & Beauty
Cd/dvd drive doesn't work. Won't open with eject button, How can I determine if it is a driver or hardware problem?
Look at the drive there should be a tiny pin hole near the eject button, insert a needle (safety pin, sewing, etc.) into the pin hole and push this opens the drive.
You can also try opening my computer and right clicking the DVD drive and select eject. After you do this close the drive and try the button again it may just be stuck if it still won't eject you can try and pop off the front of the drive (very simple it locks back on easily) and find the place where the button connects to the drive to eject and push it, If it still won't open it is your hardware.
Jan 18, 2010 | Dell (3410160) Plug-In Module DVD Drive
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick. When I turn on my camera I get an error message"memory card error" then when i press to view pictures it...
Turn the Canon Powershot A560 over so the bottom is facing up.
Locate the door on the bottom of the camera. The door is labeled "CARD/BATT. OPEN."
Place your thumb on the slider on the door. Push the slider up to unlock the door. Then, slide the door out to open it.
Find the SD card. Inside you will see four batteries and the tip of a small plastic disc. This plastic disc is the SD card.
5
Eject the sd digital memory card. To eject the card, gently push on it and then release the pressure. The SD card will pop out part way. Go ahead and pull out the card.
6
Turn the card so the writing is right-side up. On either the left or right side of the card, you will see a grove with a tiny plastic switch in it. If the switch is at the bottom of the groove, the SD card is locked.
7
Unlock the SD card. Using a fingernail, slide the switch to the top of the groove. The card is now unlocked.
8
Return the SD card to the camera. Place the card in the slot and push down until you hear a click. The card is now successfully reinstalled. Do not worry about inserting the card the wrong way, because it will only fit one way.
Nov 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I can't get the memory card to stay in the camera. The eject buttom pushes it out.
You haven't said which KM model you have. But on most of them one push on the eject button makes the eject button pop out in order to be ready to use on the second press which ejects the memory card. After pressing the button all the way in to eject the card, the button should latch back into the "parked" postion.
Before re-inserting the memory card make sure that the eject button is already in the parked position. If it isn't then you'll get the problem which you describe.
Oct 12, 2009 | Konica Minolta Cameras
The nexlink CL51 has a small button that you depress to eject a plastic card. How do you keep the button from sticking out?
After you eject the PCMCIA card you can push the button in until it clicks and stays in. Now you insert your PCMCIA card into the slot and if you want to eject the card you push the button and it will pop out then press the button to eject the card.
If this pressing the button in doesn't lock the button in place, then the spring catch on the button is broken.
Jul 08, 2009 | Computers & Internet
Disc stick in console
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-106
May 16, 2009 | Nintendo Wii Console
MacBook Force Eject CD
worked for me:
1)open Terminal
2)copy this into it:
diskutil unmount disk1
diskutil eject disk1
3)press enter
4)cd comes out
found here: http://condonethis.com/mac_eject/
Aug 11, 2008 | Apple MacBook Mac Notebook
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Olympus EVOLT E-300 Digital Camera Logo
124 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
