Question about Sony KP-EF41 41" Rear Projection Television
Channel skipping in Sony Rear projection KP-EF41 TV
The TV is automatically skipping past program channels - we cannot get it to stay on one channel to watch.. How can we fix this?
Thanks.
  • claire_lusia Jan 31, 2009
    danman1453,
    Thanks replying.
    The flipping is happening at set intervals, less than 1 sec per channel. It flips through them all and finishes on a blank channel.
    We completely blackened the room too so no other IR sources are interfering. Changed the batteries in remote, that didn't help..
    Thanks for that suggestion, we tried but nothing showed up.
    I should have added that the tv has been working fine until today.
    The model is KP-EF41 (Is that the sort of info you need? I'm hopeless with this kind of thing!)
    Thanks again.
    Problem Solver:
  • 11 Answers
Is the channel flipping always happening at set intervals? Or, just randomly? Try replacing the batteries in the remote. If that doesn't work, start looking for other sources of IR(infrared). In some rare cases, direct sunlight on the TV will get it to do strange things.
Posted on Jan 31, 2009
  • danman1453 Jan 31, 2009
    Do you have a cellphone with a camera or digital camera? IR is not visible to the human eye. But, cell cameras and most digital cameras can see it. It shows up as a purple to white light. Turn off the lights again and look for anything flashing around that color while looking though your camera. If you can't see anything, then you know it isnt interference. What is the exact model of your TV?
    other than that, I suggest asking someone who specializes in rear projection TV repair. After it cycles though the channels, does it start over? Or does it just stay on the last channel? Have you tried unplugging the TV, leaving it unplugged for 15 mins or so, and trying again?
Block unwatched tv channels
Look in the main menu for programming---most sets have a way to manually skip out or delete channels in the up/down programmed menu.
Mar 19, 2012 | Vizio VW32L 32 in. LCD HDTV
How do I set my TV channel to 3 without the remote?
Hi John,
If channel 3 is skipping by the unit when pressing the channel button key at the front panel, it might be accidentally deleted on the channel selection. If you don't have a remote control, there's no way to add it on the selection. All you have to do is to re-scan the channel by entering to Set-up Menu. Press the Menu button key repeatedly at the front panel to show the "On Screen Menu". Select " EZ Program" to automatically finds and store the channels available at your area. Once the scan is finished, you can now watch all the channels available including channel 3.
Please let me know if you need further assistance.
Kind Regards,
Jdvillanueva
Nov 24, 2011 | Zenith C27A25 27" TV
I have dish network and its programmed to work on channel 60 of the TV set, but lately the TV has began changing to a random channel from the "Favorite Channels" list and its making watching...
Hi my nameis Mike Houston of DISH Network and I see you have the TV setup to watch yourprograms on channel 60 and the TV is skipping off that channel. You want tomake sure the TV is on channel 60, make sure the remote is in SAT mode and tryto go to different channels and make sure it stays on the satellite channels.If you have any questions please e-mail me at michael.houston@dishnetwork.com.
Dec 08, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Televison & Video
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
Nov 29, 2009 | Insignia IS 20" TV040919 TV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Tv will not program in digital signals; only anolog from direct tv box
Any TV hooked up to a cable or satellite box can only "see" one channel...the set-top box (STB) converts the channel you are watching to (usually) Ch. 3 or 4. With cable you can split the input if your TV has 2 RF inputs, with a dish that won't work.
That's why the TV stays on Ch 3 and the STB changes to whatever you want to watch.
Dec 20, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Sep 09, 2007 | Zenith SY2751Y TV
Sony KP-EF41 41" Rear Projection Television Logo
153 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
