Question about Toro Lawn Mower With Toro Power Tools
Mower won't turn over
I have a Gravely 5660 that won't turn over in the winter. I have had it tuned and the carb adjusted. It runs good in the spring and summer. We have alot of snow and I have a snow blower attachment for it. I would really like to snow blow, rather than shovel. I put in a new plug and checked for spark to the plug and gas to the cylinder, all there, just no start. Help!
John
PS I had to put in Toro, the site would not accept the name Gravely. It is a Gravely 5660 model # KE301S
  • js130391 Feb 01, 2009
    The Gravely 5660 is a riding mower that has different attachments that can be changed as needed. The mower is made to operate in all types of weather. Why won't it start in the winter? Are there any switches, such as an oil level switch? I also don't know how old this unit is, I bought it used about five years ago. I have it in my garage. Last winter and this winter are the only times I have tried to use it in the winter, since I have had it. As I mentioned before, after the past winter I had it tuned and a new battery. Still no start. Help.
    Problem Solver:
  • 6 Answers
Keep it in the kitchen over night. Or anywhere that is environmentally controlled for that matter. Should start right up as soon as you get it outside.
Posted on Jan 31, 2009
2 Suggested Answers
  • 4 Answers
SOURCE: mower
If it sat for some time without running aslittle as 30 day the fuel is probly stale and needs to be drained and the carb cleaned and possibly a new spark plug
Posted on Feb 05, 2009
Lawnmowers; mine is not starting. First use this year I believe the fuel might be gummed up from sitting over winter. How do I clean this out?
When gasoline sits for an extended period of time the "varnish" builds up inside the carburetor and can keep your engine from running. If you suspect that this has happened, the only good solution is to first replace the carburetor, and then ALWAYS use a Fuel Stabilizer every time you buy gas for your lawn mower.
Also, at the end of a season, it is always a good idea to run the engine until it is dry and out of gas before storing the lawn mower over the winter. A fuel stabilizer should keep your gas fresh over the winter, and the lawn mower will start up quickly in the spring. If you are the cautious type, always buy fresh gas at the beginning of every season, and NEVER forget the fuel stabilizer no matter what. Gas starts turning bad after just 30 days....
Rayko
May 23, 2015 | Garden
Gravely 23 hp zero turn mow starts but wont continue running.Whats wrong?
Sounds like a carb. problem to me. Needs to be cleaned. May need a new fuel filter also.
Jul 14, 2014 | Craftsman 10.5 Hp 33" Commercial Cutting...
How do I tune the carb on a Kawasaki 6.5HP engine (fitted to a MTD Sprinto mower? The carb is marked 'LMJ' and has a sprung adjusting screw with a slotted head. It also has a black plastic adjuster that...
the pin is the needle & seat / start the engine & warm up the spring loaded one ideling screw / black one fuel/air turn this in until almost stalls then anticlock wise till is running smoothly
Aug 11, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Briggs as Stratton 6.75hp 190cc push mower by Craftsman (Crapsman!) will not run unless I hold the throttle open!
adjust air fuel mixture screw on main jet ,start about 1.5 turns out and slowly turn in till runs smooth
Mar 01, 2012 | Measuring Tools & Sensors
Which has the most advantage fall or spring tune-up of riding mower?
Spring, especially if you are doing it yourself and don't have to wait in line to get it into the local shop. If you do a lot of fall and winter tasks with your rider like haul wood or blow snow, then fall works, too. If not, then a fall tune up is wasted, as it will just sit there all winter gunking up (or not, if you have run it dry).
That's the news from Lake Woebegone:)
Farmerbear at FixYa.com
Sep 17, 2010 | Toro Lawn Mower With Toro Power Tools
I need to know how to adjust the carbureator on an tecumseh lawn mower model number 143.954500
If it has a float type carb, open it 1.5 turns. If it has a diaphram open it one turn. If it has a Walbro carb, there is no adjustment. Once you get the engine started you may adjust the carb to fine tune. Open until it begins to lose RPM's then close until it starts to lose RPM's. Return to a point between the two. Good luck...Lee
Sep 05, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Hard start
remove the carb and take the fuel bowl off ; soak it in gas for a few days; clean it good with carb cleaner spray in every hole using the straw; reassemble; clean fuel tank; add fresh gas. If this dont do it , you may have to adjust the carb ,turning the screws 1/4 of a turn at the time til you get it running and then fine tune it
Jun 10, 2009 | Poulan "Poulan" Push Mower
Mower
Jan 31, 2009 | Toro Blowers Rake and Vac - Electric...
Toro Lawn Mower With Toro Power Tools Logo
367 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
