Question about Whirlpool AWM6100 Front Load Washer
AWm 6102 spin lights flash & won't start
When you switch on, the 1200 spin light comes on and stays on for about 10 seconds. Then it goes out and teh 800, 100 and 0 spin lights (but not teh 400) start flashing. When I press teh pause button to start the machine, nothing happens.
I have checked the filter at bottom right, checked the door is properly closed and that teh water is switched on. It was woking fine 3 days ago. I am in SW France but I have used it twice since the storms and power cuts. Onlyother clue is that it is in quite a damp cellar.
Is this something I can fix or do I need to call out a repair man?
SOURCE: whirlpool front loading washer
I am having trouble starting the washer . I set the cycle on casual and press the start button and the washer sensor showed to " Done" instead of starting. I only bought it three months ago.
Posted on Jul 19, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool AWM 6100/s Front load washer
That is either a faulty timer control, or more probably a faulty door latch.
I think you need to replace the door latch.
Posted on Nov 01, 2008
  • 4 Answers
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Posted on Dec 13, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
  • 14 Answers
SOURCE: i have whirlpool duet ghw9100lq does not start only flashing
select pause/cancel twice if it still does not unlock. It is not unlocking because of water still in the system, run the drain spin cycle manually if that does not work you will have to clean out the lint trap and the water left inside will drain on your floor. To clean the lint trap. there is a panel at the bottom front of the washer. along the bottom of the washer there are three torx type screws to remove the panel these will be above the drawer unit if you purcased the stand. remove the panel by lifting from the bottom. then in the center you will see a plastic cap. twist the cap to remove. this is your lint filter. it pulls out and has a cup shaped piece attached to it pay attention to how it comes out im not sure if you can put it in wrong. clean the area out. there may be some water to spill out depending on how much is clogged in your system. replace the cap once you have cleaned it out this should help with your problems.
Posted on Mar 22, 2009
2010 volvo xc90. low beam headlight comes on. stays on about 10 seconds, flashes on and off 5 seconds, goes off 5 seconds. repeats 3 or 4 times then goes off and stays off. replaced bulb and ballast.
does it have daytime running lights that sensor could be bad or signal light switch ...signal to the opposite side light goes out to see if comes on
Nov 14, 2017 | Volvo Cars & Trucks
Crank, no start on 1994 honda accord EXi
you might need a fuel pump relay under dash 10 min fix/and your d4 flashing light bad transmission.
Mar 05, 2014 | Cars & Trucks
2005 ford 500, won't start a lock light is
need to reprogram ignition key security system when battery disconnected. turn ignition key to the on position for 3 to 10 seconds until the lock light goes out then start vechicle.if lock light dont turn off turn ignition switch to on position 30 seconds until lock light turn off.
Jun 12, 2013 | Cars & Trucks
I have a 2003 chevy malibu that won;t start. When you turn the key to on the Theft System light comes on steady ( no flashing). I t used o go into this mode periodically where the Theft System light...
I have had the same problem. This has happened to me three times in the past nine months or so. Per the owner's manual, you turn the key to the on position and wait about ten minutes. This resets the system and when the "Theft System" light goes out, it starts right up. I did this each time and it started right up.
Jan 02, 2013 | 2003 Chevrolet Malibu
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Hi, I have a HP Persario CQ60 Laptop. W hen i switch it on, the power putton and wifi light up, the little power light turns on and i hear the CD rom drive for a couple of seconds but nothng else hhappens...
mines does the same but wen u here it start up an the screen goes blank take the battery out then it will say start windows normaly or safe and safe made networking click on safe mode networking and u can use your laptop again but with no sound hope this helped
Nov 18, 2010 | Compaq Presario CQ60-220US PC Laptop
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Whirlpool AWM6100 Front Load Washer Logo
224 people viewed this question
Dan Webster
Dan Webster
Sal De
