Question about Zanussi IZ12 Front Load Washer
E40 fault code zannusi washing machine.
Machine will work bout will not spin. do i need new brushes
    Scholar:
  • 106 Answers
You could look here:
RepairClinic.com (good)
espares.co.uk
AppliancePartsPros.com
Posted on Feb 28, 2009
Error code E40 on a Electrolux Front Loader Washing Machine EWF80743. What does it mean and how can I fix it?
E40 relates to door lock faulty or not closing - you probably need a new door lock, but check the catch on the door hasn't snapped off first. You will also get E40 if you try to start the machine with the door open.
Dec 01, 2017 | Electrolux Washing Machines
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
E40 fault on zanussi washing machine is it worth repairing or to buy a new one 8-9 yrs old ?
A Zanussi E40 error usually indicates "Door open.Check interlock and associated wiring check door latch,check module and connections." However, what most people don't know is that most manufacturers route the poser to the door interlock through the same curcuit that powers up the carbon brushes on the motor. So if your motor brushes are worn down, the door won't lock. Your machine is about the right age for its brushes to be worn out, so I would check this out first. Motor brushes are cheap, easily available on Ebay and fairly easy to fit. Take the current brushes out, if they are less that three quarters of a centimeter long, changing them is a highly likely fix for your problem
Oct 31, 2015 | Zanussi Washing Machines
How do I fix a F53 fault ona Miele W1712 Washing Machine
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
Neff washing machine wont spin ~ drum rotates but not at speed
how old is machine if machine is bout 5 years will need motor brushes they need t be changed every 5,6 yrs, if its quite new will be ure motor pcb if its not rampin up to full on spin
Feb 03, 2010 | Washing Machines
Wont spin renewed carbon bushes and new motor ,belt okay.can you advise where the electronic detection device is on the machine,how can it be repaired
Usually located at bottom rear left of washer.
If not there, then located at top front right of washer together with timer control.
May 22, 2009 | Zanussi ZWF1430W Front Load Washer
E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Feb 20, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Oct 09, 2008 | Washing Machines
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi IZ12 Front Load Washer Logo
219 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
