Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Mower I have a Gravely mower, an old one. It ran good in the spring and summer of 07 , but in the winter 07 to 08 it would not run. I have a snowblower attachment for it and wanted to use it. I had to shovel that winter. I took it to a small engine repair shop and had the carburetor adjusted and cleaned, new plug, battery, a whole tune up. In the spring and summer it ran good, but in the winter, 08-09, again it would not start. The starter turns, but won't turn over. I put in a new plug, clean gas. It has spark to the plug and is getting gas, still no start. I would like help, we are to get more snow and would really like to snow blow, rarher than shovel. John PS It would not take the name Gravely, so I put in Toro, it is a Gravely 5660, Model # KE301S
  • Al Perry May 11, 2010
    Is the choke plate closing when you put the choke on?
  • 4 Answers
If it sat for some time without running aslittle as 30 day the fuel is probly stale and needs to be drained and the carb cleaned and possibly a new spark plug
Posted on Feb 05, 2009
I have a Ariens snowblower deluxe 30 which is a year old. Starts fine and will run. Unfortunatley it is running way to low. I have replace the gas with fresh gas ran it through completely
It is very possible the carbureator needs a cleaning. Moisture can corrode the inner parts of them if left all summer. I find that the fuel usually does not go bad over the summer. I always start my snowblower once a month over the summer and then have no problems when the snow flies again. There was a time when mine was losing power and quitting also. There is a screw on the bottom of my carbureator that needed adjusting. If you are lucky that may be all you need. By turning mine in and out a bit I found the spot where the gas was correct and it worked fine again.
Jan 08, 2017 | Ariens Garden
Ariens 624e oil type
Engine- 30w summer
5w-30 winter
Gear case L2 lube, ariens part no. 00008000
Dec 09, 2013 | Garden
Snowblower won't start this year. Machine
Did you run the engine for about 15 minutes after you added the fuel conditioner? If not then the conditioner didn't get into the carburetor and you probably will need to take it apart and clean it again. The ethanol in today's fuel causes problems in carbs that sit
Jan 20, 2013 | Garden
Briggs as Stratton 6.75hp 190cc push mower by Craftsman (Crapsman!) will not run unless I hold the throttle open!
adjust air fuel mixture screw on main jet ,start about 1.5 turns out and slowly turn in till runs smooth
Mar 01, 2012 | Measuring Tools & Sensors
1995 Jeep Cherokee running cold in the winter. Temperature guage is on the first line always. How do I replace a thermostat? Is there a summer and winter thermostat?
No, before changing the thermostat try blocking the radiator by placing cardboard between the grille and radiator. Don't forget to remove it next spring. If that doesn't help, let me know and I will send instructions on how to replace thermostat.
Dec 18, 2010 | 1995 Jeep Grand Cherokee
I have 20 year old Toro s-200 snowblower. I ran it dry last spring before storing it for the summer. Pulled it out recently and it won't run. It will turn over and run for about 5 seconds...it seems to...
When you start it keep pushing the primer too keep it running for as long as you can.this usally helps when they have been sitting without gas in them.if that don,t work take the carb off and clean it out.
Dec 03, 2010 | Garden
My ariens snowblower only works in the choke position. once i turn it where it sould be it stalls
had same problem with a small 2 cycle outboard motor last year. I had run it during the summer, put it away for the winter and when I went to fire it up the following Spring it would only run with half to full choke. Old fuel had gummed up the carburater by letting it sit in there for a few months, had to disassemble and clean all the carb parts (including the jets) and it worked good as new. You could do it yourself or take carb to a small engine repair shop and have them do it. May or may not require a rebuild kit depending on how gummed up it is. Hope this helps.
Feb 10, 2010 | Champion International Champion& Small...
My yardmachine snowblower won't stay running. It starts if I pump the primer. Fires up than dies. The fuel line isn't clogged, but once it starts it seems like the throttle cable has no tension (floats...
empty the fuel bowl & tank. start out with fresh fuel for one. then get a new spark plug if it still dont start. as far as the cable thats another deal completely but it shouldnt cause it to stall out. but if it ran last year it will this year too. always run it empty for summer storage. its your personal choice if you use a summer storage lubricant.
Feb 09, 2010 | Mtd 22" Yard Machine Push Mower
Mower won't turn over
Keep it in the kitchen over night. Or anywhere that is environmentally controlled for that matter. Should start right up as soon as you get it outside.
Jan 31, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
264 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
