Question about Samsung LN-S3251D 32 in. LCD HDTV
Remote control I wish to control the screen through the rs232 port. This is stated as a service port only (3 wire mini jck) is there a way of using this port instead of the IR handset
    Sniper:
  • 133 Answers
The only way I can find online is someone trying to get a patent for an invention capable to do this, so as far as i can find there is NO way to use your rs232 port to control the screen. Sorry.
Posted on Aug 05, 2007
SOURCE:
Need USB driver for Panasonic LQ-MD800 DVD recorder or recommendation for universal remote controller
Google panasonic lq-md800 manual and download the owners manual from panasonic. This should tell you what options you have.
Oct 13, 2016 | Panasonic LQ-MD800 Medical Grade DVD...
Rs232c port hitachi use as input
the RS232 port is not for viewing video. You want to use the VGA port. RS232 is a way for you to control your TV from a remote location via a computer.
Jun 06, 2012 | Hitachi Televison & Video
What is the RS232 port for?
RS232 is simply a serial data transmission / communication port. It has never had any signals involved in video. It has been used for data exchange between computers and for connecting peripheral devices like modems and printers to computers. It also has been used to connect a remote keyboard / screen, such as a "dumb terminal", to a computer as an additional I/O device.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 19, 2011 | iLO 3200 32 in. LCD Television
How do you use the RS-232 port to control the projector ?
you will need to get an RS232 compatable remote and wire it together
usually this will only control power on and off and not much more
this is usually done only in commercial set ups are you using it at home or work?
you would be best off getting a pro to install and load/ write code for you
Apr 15, 2011 | InFocus Proxima UltraLight S520 Multimedia...
I have an Olevia 42" LCD with the same problem
there rs232 to usb cable converter, you just buy it, and you got rs232 to usb connetor
Jan 11, 2011 | Olevia LT42HVi 42 in. LCD Television
How do i change the baud rate on the com port?
lesson 1:
not all Uart chips are the same.
many and vast chips can not do 115k buad.
why not read the spec on this old long ago non supported device.
or ask on real HP forum. this.>?>?>
RS232 was my bag for many years, could make any work.
Im sure this is in the manual , if I had a PC the book would be in my possession, at all times, why let luck rule here.
the luck of find books on old products.>??
168 page manual, i see, and no stinking index. wow.
gota love that. no?
rs232 . history, some apps set it others dont, for the who history of that. so if the APP dont that leave what, the OS, does it.
end history.
the manual stinks in this regard,
http://h10032.www1.hp.com/ctg/Manual/c00267893.pdf
il now read your manual to you (google found it in 1sec)
IDENTIfying the Communications Port You can identify the virtual COM ports used to create a
serial port connection. You may need to identify these COM
ports for activities such as printing.
Use the inbound COM port when other devices initiate a serial
connection. Use the outbound COM port when you initiate a
serial connection to another device.
To identify the communications port:
1. From the Today screen, tap iPAQ Wireless > Bluetooth >
Settings > Services tab.
2. Under Services, tap Serial Port and tap the Advanced...
button.
3. Note the names of your inbound and outbound COM ports.
4. Tap OK
(and no other hits in this manual this topic)
if you run and APP and the exit it and see the port baud wrong
you learned your APP is no good.
the spec page in this manual skips RS232 chip totally.
my guess is HP thinks its not needed.
one other hard thing to learn?
is RS232 is Not TTL 232,
RS232 real uses +12 and -12vdc levels, it bet your DEVICE unstated uses TTL232.. 5v TTL signalling.
RS-232 is for modems, and has lots more wires that just 3.
so if its 3 wire, (aka, 2wire Rx /Tx) its not ever called RS232
its and Ad hoc , 232. per the wiki on that...
why not use a real PC to do this
why not then use the USB-232 adaptor dongles sold for $3
use that to communicate, I can show you how to do all that.
using any PC running windows, and 1 extra USB port.
115k FIRST THE CHIP THERE MUST SUPPORT THIS.
THE OS IS NEXT... (the book skips all these details)
and the APP is last, the APP must support it and the OS
must let the APP, set it, (some dont, even when hardware CAN)
see?
i could not even find a docucment on what are all the chips inside
this relic pocket, pc. nada, or id have shown the data sheet too.
Jul 13, 2017 | HP iPAQ hx2410 Pocket PC
SDR-40p dont finded to WinXP SP3, and requiring driver. Sorry, i am russian.
Manual below http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Yes you must connect under RS232c Format and you must use remote commander, it appears you do NOT need a driver, you should be able to connect via Terminal Program, over the rs232 port.
Mar 16, 2010 | Sony DSR-45 Mini DV VCR
Computer control and pointing with NorthStar Goto & Autostar
Your reseller is correct. The wire (Meade cable #505) goes from an RS232 serial port on PC to a 4pin RJ plug. This plugs into the 2nd socket on the bottom of an Autostar 497 handset, the other socket being used for the curly lead to the telescope. So it goes PC to Autostar to telescope.
A common error is to try plugging the serial wire into an "AUX" ort on the telescope control panel - same connector. Not only does this not work, it can cause a lot of damage.
Wired like this you can control the scope from Meade's Autostar Suite (or many other planetarium softwares). You can also update the Autostar software to the latest 2009 version.
What else can go wrong? Well, many people want to control from a laptop, and modern ones don't have RS232 serial ports. Then you need a USB-to-serial convertor dongle, which effectively add a serial port to a laptop. But they often give it a very high port number (eg COM17) that the planetarium software does not find. Use Control Panel to reset the USB-serial-port to COM 1, 2, 3 or 4 and all should be well. But it can be a right fiddle!
Apr 01, 2008 | Bushnell NorthStar Goto 100mm 788840...
What is the right rs232 cable to connect a Denon 3808CI reciever and a Phillips RFX9600 serial extender
OK LOOKING AT THE SPECS FOR THE EXTENDER YOU DO NOT NEED TO WORRY ABOUT THE SERIAL CONNECTIONS, WHEN USING THE SERIAL CONNECTIONS YOU NEED RS232 CODE STRINGS TO CONTROL THE DENON OR ANYOTHER DEVICE THROUGH THIS EXTENDER USING THE RS232 CONNECTIONS.
IT LOOKS LIKE YOU CONNECT AN I/R EMITTER FROM AN MINI JACK I/R CONTROL PORT ON THE BACK AND THE OTHER END TO THE I/R WINDOW ON THE DENON
Feb 27, 2008 | Denon AVR 3808Ci Receiver
Samsung LN-S3251D 32 in. LCD HDTV Logo
113 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
