Question about Asrock motherboard 4CoreDual-SATA2 LGA775 VIA PT880 Quad / Core 2 Extreme / Core 2 Duo PCI-E ATX 4
Front Panel Speaker Mic Conection
I have a Numan Midi Case Manufactured By Multimedia Computer Systems. I am usung The ASRock 4CoreDual-SATA2 Mother board.
I cant seeem to locate a connector for thhe lead on motherboard, any ideas or sulutions would be greatfull. Denec
  • denec14 Jan 31, 2009
    Many thanks you know what its like sometimes. the one thing you are looking for and cant find is right in front of your eyes staring you in the face.
    Yuo Have saved me a lot of time and frustration.
    Again Many thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, the front panel audio header (connector) would be above the PCI2 slot, on the rear end/side of the motherboard. It would be marked HD_AUDIO1 and made up of 9 pins (one missing).
Good luck and thank you for using FixYa.
Posted on Jan 31, 2009
    Brigadier General:
  • 5,158 Answers
Http://download.asrock.com/manual/qig/4CoreDual-SATA2%20R2.0.pdf
Page two... i believe that would be your system panel header
Robert
    Genius:
  • 1,913 Answers
Check on mother bord chip set i se in corener of mother bord some pins
read carefully all pin down side.u se e there is audio connect the cables of audio into it.if u have manty pins like +5 etc then u have to conect pin 1 bye 1 all information of pin u gett here u can do it .
  • 13,433 Answers
Front panel audio connector. Its shown in the manual, if you don't have it hold on I'll find the details.
  • Ekse Jan 31, 2009
    the manual is available on this page
    http://www.asrock.com/mb/manual.asp?Mode...
    See page 11 for the location of the front panel audio which is labeled as hd audio in this case.
    Its #24 frton panel audio header
    On page 22 you can see the pinout of the connector.
Clock problem when i open the system
If the Date & Time changes back to some previous date when you next boot up the computer then the CMOS battery is worn out and needs to be replaced. After replacing the CMOS battery go into the BIOS and set the Date 7 Time.
Feb 22, 2013 | Asrock 4CoreDual-SATA2 Motherboard
Asrock 775i65G motherboard when i install widows xp can't continue, and hungs when setup windows excutive load,,how i fix this problem pls help me
Try installing Windows in a directory other than Windows. Let it be installed in say WINXP or whatever name you like.
Jan 13, 2010 | Asrock 4CoreDual-SATA2 Motherboard
I cant have sound in my asrock 4 core dual sata 2. i have a prcessor pentium 4 3.2 please help me
1. Go to: http://www.asrock.com/Support/Download.asp
2. Select "775" in the Socket drop-menu.
3. Select "4CoreDual-SATA2" in the "Model" drop-menu.
4. Select your operating system in the "OS" drop-menu.
5. Click "Search".
6. Find & download the Audio drivers.
Jul 18, 2009 | Asrock motherboard 4CoreDual-SATA2 LGA775...
I have asrock 4coredual-sata2, get no audio, cannot install the driver, it wont, i dont know what the problem may be.
What OS do you use? are you sure that you downloaded the right driver?
Tell me what OS you are using and I will find the right driver for you.
Jul 11, 2009 | Asrock 4CoreDual-SATA2 Motherboard
Seeking of asrock fsb 800 prescott 800 driver
You can find & download all drivers for this motherboard at the following link:
http://www.asrock.com/mb/download.asp?Model=4CoreDual-SATA2&s=775
Would like 4 Gb's of RAM in my Windows XP computer
No. If ASRock has no bios update and you can't write your own it is impossible. You won't see a performance improvement between two & four Gb anyway, spend your efforts elsewhere.
Mar 22, 2009 | Computers & Internet
Asrock4 coreduel sata 2 front panel audio header wireing
I've been there. The connections you do not have hooked up, you can leave unconnected and the computer will work, although you probably will not have sound. All the connections you ask about are audio, so you might need to look around for another place to hook them up. On some computer motherboards those connections are not alongside the power connections, they may be close to where you plug in the speakers and mic. If all else fails, you can buy a USB audio in/out card for less than $3 online and use it.
Dec 21, 2017 | Asrock motherboard 4CoreDual-SATA2 LGA775...
Front mic port and headphone
to connect your front panel header you must refer to your motherboard manual ...
it will given in detail with the pin diagram how to connect ....
check the motherboard compatibility some motherboards dont support working of the back panel header and front panel header at same time especially the old motherboards ....
almost all new motherboard supports working of both the panel headers at the same time if the motherboard supports multi streaming...
thank you
any doubts you can reply me
i am always here to assist you
bye
rate my solution
Aug 06, 2008 | Computers & Internet
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
Asrock motherboard 4CoreDual-SATA2 LGA775 VIA PT880 Quad / Core 2 Extreme / Core 2 Duo PCI-E ATX 4 Logo
85 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
