Question about Epson CX8400 All-In-One InkJet Printer
Printer error I just bought this cx8400 and was setting it up. I put in the ink cartridges turned it on and it says printer error. Itwont even prme the ink. What should I do?
    Genius:
  • 2,120 Answers
Did you remove all shipping blocks and the plastic tape on the cartridges?
Posted on Jan 31, 2009
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
Changed ink cartridges - error still says I need to change them
Call Epson tech support and then Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 20, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400 ink cartridges run out early
Epson gives you a miserable 12 ml of ink. Then it reports empty when there is still 10-15% of the ink left. I saw someone set up a brand new CX8400, print a single 4x6 photo and it said he was out of cyan. I use reusable cartridges from http://www.ccs-digital.com They hold 20 ml, which is 2/3 more ink. The chips automatically reset to full if you take the cartridge out and put it back in, so you get to use every drop. The ink is in a separate container inside the main cartridge. When it's really empty, you pop out the ink tank and pop in a new one. The tanks are under $3 each. I think this is brilliant because it's like refilling only it avoids the risks and mess of refills.
Jun 14, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Mar 05, 2009 | Epson Stylus R265 InkJet Photo Printer
I have an Epson CX8400 printer and I just installed new ink cartridges (genuine Epson)all four and I get the error message "cannot recognize ink cartridges".
Try the following:
1. double check the part numbers of the cartridges and also their expiration date.
2. reseat the cartridges
3. after you place the cartridges back, close the scanner part and press and release the stop button.
4. If same issue, either an issue with the cartridge(s) involved or the printer itself
Hope this help
Feb 25, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson cx8400 printer error
In order to fix error code cx8400 on Epson Printer, make sure that you have removed the cartridge once, and then place it back again. If you don't know the process, you can take help of the manuals given to you along with the device. And, if by chance, your issue is not resolved even after resetting the cartridge, it is important for you to take instant help from the experts. Just call them now on Epson printer support phone number to connect with the professionals, and they will quickly resolve the problems.
Jan 31, 2009 | Epson CX8400 All-In-One InkJet Printer
Replace ink cartridge
Took printer back- power up and take all carts out in sequence that would not register, then put them back in sequence- works fine now! At one time you could not do this with Epsons but it seems you can do so now. Printer happy- me happy- £50 worse off as bought another set of ink carts so I won't get caught out again with no ink. However given one black cart for my trouble so happy again.
Sep 16, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson Cx8400 waste ink pad error
this site is widely used for this problem.
http://www.ssclg.com/epsone.shtml
Jul 22, 2008 | Epson CX8400 All-In-One InkJet Printer
Expson CX8400 All-in-one printer
I had a problem with one of my Epson ink cartriges and called the company and they replaced it for free. Also many companies that sell knock off ink cartridges now have fixed the problem and now they are recognized by the printer.
Jul 11, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
62 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
