Question about Nokia 3100
How 2 repaire insert sim card nokia 3100? - Nokia 3100
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Sir
pls try this solution, however pls test the contuinity of the jumper lines indicated on the pic before putting the jumper. only those cut lines should need jumper... not that we should use fine magnetic wire to avoid short circuit..
tnx
Posted on Feb 03, 2009
Enter restrictions code on nokia 3100
Hello. You can get the accurate unlock code for a Nokia 3100 from
http://www.unlocking4u.com/nokia-3100/rs5wp9/ at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 3100 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3100.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3100 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3100 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3100
Sep 26, 2014 | Cell Phones
Nokia 1200 insert sim
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Sep 21, 2012 | Nokia 1100 1101 1108 1110 1112 1200 1208...
Hello pls help. my nokia 3100 wont turn on if i insert a sim card, but it will turn on if i didn insert a sim card. what is the problem? pls help
It is a software problem. Contact your nearby service center and they will fix the problem by updating your software.
Nov 03, 2010 | Nokia 3100
My nokia 3100 is only showing insert sim card
is your sim card inserted if yes look it again is it in the right way... try to switch off your phone.. take of battery take of sim card  wait for 5 min and put them back and wait 20sec then turn off ur phone
hope it will help u
thanks
Apr 16, 2009 | Nokia 3100
MY PHONE NOKIA3110 SAYING NO SIM CARD INSERTED.
If Nokia said it can not be repaired, it can not. Buy another phone and insert your Sim card in to the new phone so you'll have most of your data at least.
Apr 05, 2009 | Nokia 6111 Cellular Phone
Can you transfer phone contacts from nokia 3100 to the sim?
yes...
go to menu>contacts>copy>choose from phone to sim card
after that, u can choose either to copy as u wanted only or all of contact that u have...
please make sure your contact in your phone does not exceed with maximum contact that your sim card can hold.otherwise it only copy until the amount that your sim card can hold only...
Mar 21, 2009 | Nokia 3100
How do I get the sim card out of a 3100 nokia
1.remove the back panel
2.remove battery
3.remove sim lock
by this you can remove your sim out from your phone.
*but switch off your phone before removing your battery.
Dec 15, 2008 | Nokia 6010
Finding the sims phone number
make sure that your old sim haven't reach it expiration date yet!
load a card.
Nov 16, 2007 | Nokia 3100
Nokia 1112
hi
common cause of insert sim is that your sim card doent contact to its sim card terminals. try cleaning its terminal or bending its sim card cover towards the sim terminal or put any small cut or folded paper just like the shape of your sim and place it together w/ your sim.  that makes your sim compress more to its terminal.
if samething happens then its already hardware problem or simcard terminal loss its connections..
try it...
Oct 17, 2007 | Nokia 3100
Insert sim card 3200, i think its hard ware, thanks
1. Yes, that's true this might be ur handset's sim slot problem, to confirm about that inset another sim in ur handset, if ot doesn't work then go to nokia care.
Aug 14, 2007 | Nokia 3200
Nokia 3100 Logo
122 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
