Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Connect or disconnect hose on upright vacuum
When using an upright vacuum and not using the tools, should the hose be connected or disconnected when vacuuming
The hose has to be connected to engage the suction. To test this, is there suction in the hose when you turn the vacuum on? If so then the hose needs to be connected.
Posted on Feb 17, 2009
How do I unstop vacuum so that the dirt moves through the hose? Vacuum has suction but wont move the dirt through to the bag less container.
If you can disconnect the hose and feel vacuum at the hose connector, that indicates that the hose is plugged. Disconnect both ends of the hose and hold the hose over a plastic garbage band to ketch debris and shove a broom handle through the hose to dislodge any obstruction. Reconnect the hose and test for vacuum.
Feb 22, 2015 | Dirt Devil Ultra Vision Turbo Bagless...
I have a Hoover F5914-900 Steam Vac. I have used the upholstery/stair tool in the past with success. Today I installed the accessory tool , but when I turned the machine on, the fluid drained out the...
If fluid drains out through the bottom of the machine, rather than through the brushes, you most likely have a leak in the quick disconnect valve. ( part # 43523004, msrp $4.99 ) This is the small valve that the end of the hose connector snaps on to. If this is the problem, it will also leak when doing normal rug shampooing. This is a somewhat common problem with this machine. The valve will need replacement.
Jun 18, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hose placement bissell 8910 top will not fit
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Apr 05, 2010 | Bissell 8910 ProHeat Clear View Upright...
I have a bissell shampooer and it does not **** the water
Check the hose's and make sure there connected and that it doesn't have a hole in it. Make sure the water resivoir is seated correctly. Disconnect hose and check if it's clogged.
Dec 12, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The suction isnt working
disconnect the hose where it goes into the base and see if you have suction there.if you don't then your intake hose is clogged.thats the hose that your long stretch hose connects to.take a coat hanger and bend the tip so the end is rounded.work it down into the intake hose at the bottom and try to push the clog out through the bottom.make sure your filters are clean and the bag isn't full. please leave feedback
May 05, 2009 | Panasonic MC-V5005 Bagged Upright Vacuum
I have the upright kenmore progressive with direct drive and the filter canister stops bringing in air and picking up when hose is put into vaccum, when you remove hose and use as an attachment it starts...
Check the hose after the brushes. With this problem there is normally a clog in between where you disconnect the hose (to use attachment) and the brushes that clean the carpet.
Dec 21, 2008 | Kenmore 31913 Progressive Direct Drive...
Vacuum making loud noise (like hole in tube)
I have the same vacuum - it's a clog in the brush area, or where the hose connects to the base. Unhook the hose, like you're going to use a tool. Lay the vacuum flat, so you can stick something in the plastic tube (at the base where you disconnected the hose) without the awkward angle. I use a dryer vent cleaner, but you could probably use a wire hanger. Push through until it comes out through the brush area...should fix your problem.
Nov 13, 2008 | Kenmore Progressive Bagless Upright with...
Kirby sofa cleaner
Hi, my name is Jon and I have an Ultimate G Kirby and have sold Kirby and the solution to this problem it is very simple. All you have to do is first disengage the belt by lifting the hood and twisting the plastic thing that says Kirby. Twist it all the way till the red arrows meet up then you will know that the belt is disengaged. Next you're going to disconnect the front by pushing the small metal lever/lock under the hood to the right and the front end should come right off. REMEMBER put the vacuum on the highest setting so this will be much easier to do. Then what you want to do is connect to hose and you will do so by connecting the hose in the same manner in which you would connect the front. There is a perch for the hose or any of the other attachments to rest their "feet" on as you will see the end of the hose is contoured to fit the Kirby in the same way the front end does. Lock the hose in place with the metal lever/lock by putting it over to the left. REMEMBER to disconnect the belt when you take off the front end and ALSO to reengage it when you put the front back on. I hope to have solved your problem, and I'll talk to you later!
Nov 18, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
117 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
