Question about Electrolux E23CS75SS Air Conditioner
Electrolux Type R51K/BGE
My Electrolux Kelvinator split system has turned itself off and all the lights on the indoor unit's display are flashing (Timer, auto, defrost & powe). I tried using the remote but nothing happens. I turned the unit off and back on using the main switch and it starts working again but only for a few minutes and then the same thing happens. I can't locate the model no, but the remote says 'Type R51K/BGE'. It's a large reverse cycle unit.
Please help!
5 Suggested Answers
  • 56 Answers
SOURCE: Lost button on remote control(reset/lock button )
It is possible to google the manufacture and see if theyre tech support/contact us lines can locate one for you. Hope this helps.good luck
Posted on Feb 12, 2009
  • 3 Answers
SOURCE: Electrolux Kelvinator - Unit on defrost
Check the defrosting sensor on the coil or the solanoid on the reversing valve.
Posted on Jun 07, 2010
hvac1960
  • 2133 Answers
SOURCE: I have water dripping from
Check air filter, cooling coil and also drain pan for dust blocking. Clean it.
If
Posted on Dec 02, 2010
bunnydawg
  • 5158 Answers
SOURCE: hi there my 1 yr old
take the batteries out for about a half hour or so. that shouuld reset it.
Posted on Jun 15, 2011
My kelvinator split sys turns on for about 5 min the 4 lights flash blows warm air have no manual
If the 4 lights are the indoor unit indicator lights, it is a fault code. Do some lights stay on or do all flash? What model is it? Kelvinator ( In Australia) are sourced from various OEM suppliers, different models will have different fault codes.
Mar 16, 2015 | Heating & Cooling
I have a kelvinator Electrolux split air con model r51k/bge it doesn't seem to keep coolits set on 17 and the control says cool the fan says high but no cold air comes out wat could be the pro
many reasons could be there, check that the outdoor fan working or not if yes my be the compressors is tripping, if no, check the volt for outdoor, check the gas and the leakage
Nov 21, 2014 | Electrolux Heating & Cooling
I HAVE AN ELECTROLUX KELVINATOR ESG21HRIA SPLIT SYSTEM,
do you have the user manual?? i am in desperate need for this!
Mar 10, 2012 | Electrolux Heating & Cooling
I have water dripping from the front of my airconditioner model R51K/BGE Electrolux Kelvinator
If
Dec 02, 2010 | Heating & Cooling
I have an electrolux split system airconditioner model no.EJE24HRA it has not been used for months but the display panel is suddenly flashing Auto and if I do turn it on it suddenly switches itself off...
there is a auto switch button inside the indoor unit just above or on the side of digital display but you must open front panel to get access to it when you do, press that button which says auto once to cancell it from coming on than set your mode on the remote to heating then press start or on button on remote. be sure to set temp to atleast 30 degree before starting it
Sep 27, 2009 | Electrolux E23CS75SS Air Conditioner
When a heatpump goies into defrost, the unit is in a/c mode. and cool air is inside. You may have a bad reversing valve or bad defrost board.
Sep 25, 2009 | Electrolux E23CS75SS Air Conditioner
Hi, I have a KSR27g split system air conditioner. The unit turns on with the button on the front under the panel. The unit will not turn on with the remote (remote is brand new) have tried different...
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Jul 14, 2009 | Electrolux Heating & Cooling
Feb 07, 2009 | Heating & Cooling
Heating & Cooling Logo
1,820 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
