Question about Asko D1716 Built-in Dishwasher
Need explanation of control pictures please
Have just started using the asko superior again after a year and cant understand the icons on the control panel.
  • 4,636 Answers
Click below and download manual. Hope this helps you....
Sea Breeze
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Posted on Jan 31, 2009
Mains on/off switch issue asko 1473 superior dishwasher
then call a repairman and have that control replaced .
Dec 24, 2015 | Asko Dishwashers
Does anyone know where to buy replacement cutlery basket for Asko D3100?
They are sold by dimensions and you can find them here in the UK:
http://www.partmaster.co.uk/cgi-bin/search.pl?query=Asko%20asko%20cutlery%20basket&f=522778&path=104426&shop=asko
AU
http://spares.bigwarehouse.com.au/index.php?cPath=69465_69466_81477
Actual part number 8801239-77
another AU site part listed more than 50% down the page using the PN above:
http://www.albury.net.au/~allfix/catalogs/dishwash.htm
Sure does seem a bit pricey on the AU sites....
To me as a 40 year tech a dishwasher cutlery basket is a cutlery basket. Find one that will fit the dimesions of your dishrack alloted cutlery basket space and buy it. The first link is a good start.
Kelly
Apr 16, 2011 | Asko D3251FI Dishwasher
Need replacement control selector pad mounted on top of door Asko 1805 fully integrated
Hello, Welcome to FixYa.
The part you`re looking for on the Asko 1805, as I understand your description ( please correct me if I misunderstood )...
the overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (then a -0 for white or -33 for black depending on the color the last digit?digits change).
Check "repairclinic.com" part number 764259, retail for approx. $80.
Hope that answer`s your question. Let me know if I can assist you further.
Thank you for choosing FixYa today.
Please take a moment to rate the information I provided for you and a testimony if you fell it`s warranted.
Good luck.
Regards,
Macmarkus :)
Sep 04, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Model d3121 does not "heat"... when I use it the water don't be hot and the dishes doesn't dry. you can answer in french i'll try to understand ... as you can see i'm not bilingual but...
In my case, the problem was with the control card, located behind the control buttons on the front. The relay driving 120V, 10A to the heaters had one pin dissoldered, probably because of heating. It was dark around the pin. See the picture attached. The top part showd the PCB with the faulty pin marked by a red arrow; the bottom part shows the other side of the PCB with the relay itself.
Remember that this relay/pin drived 1400 W.
I found the electrical drawings here:
http://www.greatplainsapplianceparts.com/order/Parts%20Manuals/Asko/ASKO-Dishwasher/D3121%20%28DW20.1%29%20SS.pdf
Oct 01, 2008 | Asko Dishwashers
Asko Dishwasher 1473 - 262
The sound is the drain Pump I believe ,it turns on to make sure the unit is clear of problem so it can re cycle and start again.
Jun 12, 2008 | Asko D1716 Built-in Dishwasher
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Asko D1796 will not start properly
It sounds as if you may have A bad control board. It could be causing the heater element to come on when its not supposed to (usually a stuck relay) and not filling the machine with water. you could also have a bad control board AND a bad fill valve, as a stuck relay for the heater shouldn't affect the fill valve circuit. The bad news is that these asko control boards are $350 to $450 for just the part, the good news is that the control board is under a 5 year warranty (for only the part, not the labor to change it) as are the pump motors and any timers. Also, if you are just out of warranty, find your date of installation, as asko warranties start when you install it, not when you buy it (if you moved into the house and it was there when you moved in, and you are the first owner, submit a date of occupancy and that's when your warranty started)
Jan 01, 2007 | Asko D1796FI Built-in Dishwasher
Asko D1716 Built-in Dishwasher Logo
248 people viewed this question
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
