Question about Alvarion BreezeNET AP-10 PRO.11
I have a breeze access that i have forgotten the now what is the ip address that i can use to acess it even if i press the reset botton
    Sergeant:
  • 366 Answers
Use this page for some detail on your Acces point
To connect to it use a lan cable and find Gateway IP address in your IPCONFIG command in Start, Run, CMD (click ok and use command screen)
Posted on Jan 31, 2009
Hpow u change ip adres
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
Aug 07, 2013 | Computers & Internet
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I am not able to login my new dwl-2100 AP acess point
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi If you are still not able to access with above ip then press RESET button for 10 seconds it is in back side of router then all settings defaults then you can access it with above ip . Let me know if you need further assistance. Thanks for using FixYa.
Oct 09, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Can not acess Http://192 168 1 1 so I may password My router
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access it then press RESET button for 10 seconds it is in back side of router. Then all settings defaults then you can access it with default above ip. Let me know if you need further assistance. Thanks for using FixYa.
Oct 08, 2010 | Computers & Internet
How do i change to a new password
reset your router press the botton at the back you see there a small botton used ballpen to press it so that it will reset. or just simply type the ip address of the router then it will go to the website then you can changer your password
Mar 03, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
JerelB. Can't acess my router
I have listed possible solutions to your problem. Please try the following:
If the ethernet light on the router is not on, check if the cable is properly connected to the ethernet port of the computer and router.
If you cannot access the setup page of the router and it is not even prompting for your login credentials, check the ip address of the computer.
To check the ip address of the computer, go to the command prompt, and type ipconfig. (To go to the command prompt, click Start-> run/search -> type cmd, then click ok).
Take note of the default gateway, and try accessing the router using the default gateway.
If the IP address is 169.254.x.x then this is a possible problem on your network adapter. Try to reinstall the drivers.
Once you are in the login screen of the router but still you cannot access the router page, you will need to reset the router. Press and hold the reset button for 10 seconds then power cycle the router.
The default ip address of the router is 192.168.1.1. Type the ip address in the address bar of your browser.
Try logging in again without a user name, then the password is admin.
Please let me know if you need further help regarding this issue.
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
D link dwl 700ap
The default IP address of most Routers is 192.168.0.1 and subnet 255.255.255.0
If you have setup the router earlier with you own network addresses that are different than the default you will have to start again from the beginning and push your routers reset button long enough so the router will reset to the default or factory settings. Then set your computer to automatically get its IP from the router via DHCP. If you have set the router to allow UPNP then you might be able to invoke or CALL the router by right clicking on your LAN connection in the Network connections page. This is if you are running windows. Mac or linux is different but the idea is the same. Hope this helps.
Sep 25, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Alvarion BreezeNET AP-10 PRO.11 Logo
614 people viewed this question
Top Alvarion Computers & Internet Experts
John Anderson
John Anderson
randy yarpos
randy yarpos
Are you an Alvarion Computer and Internet Expert? Answer questions, earn points and help others
