SOURCE: My 2008 Nissan altima will not start sometimes
do the brake lights come on when you press the brake? If not the brake switch is bad. If they do, check your brake fluid. Ive heard of these Altimas having bad master brake cylinders. If your brakes(pads) are good and your fluid is really low, this may be your culprit. Should be covered under warranty.Let me know how you make out.
Testimonial: "Thanks"
SOURCE: hyundai getz 2008 manual turns
The poor performance of the car makes these faults to come up and undermine the working of the engine. A full check up on the fuel and firing will confirm the fault on the car engine. please check these tips: http://www.fixya.com/cars/r5843031-tips_check_car_not_start To check the performance of the car you can start by checking from Then we must check with the electrics. The spark intensity is most important .Remove all plugs to check gap and condition of plugs. The black plug indication will confirm that the performance is bad whereas a fully fired plug without deposits must be the ideal view. Check the HT coil and the HT wires, if the intensity is bad this must be swapped and checked to confirm. DO NOT CHANGE any part without a confirmation by trying with a replacement from another vehicle or friend. Finally the LT trigger to the coils must be checked be it from the platinum points or an electronic ignition unit. The voltage of the trigger must be high to give the best HT output. Now use a strobe to check the Timing on the engine. Adjust if needed to see the TOP DEAD CENTER-TDC- mark. If there is valve noise make sure that the tappets are set properly so that the valves seat firmly for the best compression. Also check compression of engine if there is imbalance on the engine or reduced power.
SOURCE: 2008 Nissan Altima won't shift gears while driving
If the RPM's Flare, youv'e gone too long without
recognizing a trans that slips
It will have to come out & be rebuilt,most likely.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
SOURCE: My 1999 nissan altima won't start, no crank,not even a click. All lights are ok, stereo etc.
check fuseable link near battery if it's blown would pay to look for short circuit before doing much more
If no check engine light on, check fuel pressure. If CEL is on you have to troubleshoot code.
