Question about Akai LCT3201AD 32 in. LCD Television
Picture size is always too big. No matter what the zoom setting or display setting, the image borders fall outside the screen. AKAKI tech support tel # is diconnected.
    President:
  • 2,961 Answers
There are only normally 4 options for picture size, 4:3, 16:9, 16:9 zoom and auto, unless you are using High definition. Any other settings should be found in your cable reciever box as the picture size can be altered in its settings also.
Posted on Jul 30, 2007
SOURCE:
Picture size mis too large. No matter what screen ratio or zoom setting, the picture borders are outside the screen. AkAI tech support phone # is no longer in serrvice.
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected. Some Dish Network boxes have Size buttons on their remotes and also in their main menu. It's difficult to determine the repair without knowing the types of the peripherals. Hope this helps.
Jul 30, 2007 | Akai LCT3201AD 32 in. LCD Television
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way...
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Aug 23, 2011 | Vizio 42 in. LCD TV
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
PICTURE WONT FIT ALL CHANNELS
Look for the button labeled format , zoom, aspect or picture size and press it until picture is the size you want.
Mar 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Tv stuck on zoom
Hi
Thanks for using FixYa. Please check your cable box settings first. Sometimes the remotes have a picture size button on them, and the in-laws could have pressed that by accident. Check the TV settings, press Menu Button & then go to WINDOW/IMAGE SIZE. Now select normal size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen. If still the issue persists, then you’ll need to go to the service menu. To go to the service menu please start with the TV off and press mute > 1 > 8 > 2 > power the remote on. Now the TV will come on with the menu displayed and from there you can change the settings as required.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 27, 2008 | Televison & Video
Picture Size
check your picture setting if it is on zoom, you can set it back to auto cinemal or panorama
Sep 09, 2008 | Polaroid 3211TLXB 32 in. LCD Television
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Akai LCT3201AD 32 in. LCD Television Logo
360 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
