Question about Akai LCT3201AD 32 in. LCD Television
Picture size mis too large. No matter what screen ratio or zoom setting, the picture borders are outside the screen. AkAI tech support phone # is no longer in serrvice.
    Novelist:
  • 192 Answers
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected. Some Dish Network boxes have Size buttons on their remotes and also in their main menu. It's difficult to determine the repair without knowing the types of the peripherals. Hope this helps.
Posted on Aug 05, 2007
SOURCE:
Hi, I have this TV that i love, recently i see the picture is bigger and i cant see the subtitle and or words around picture like Channel name or ads running below picture
See page 24 of the included manual The view mode button is just above the channel change button. The manual shows how the screen will zoom etc as you right size the view for you. I've included an image of page 24 in the event you can't read the PDF file.
It is east to mis the channel scan and not realizing it change the aspect ratio
I hope that this helps.
https://content.abt.com/documents/37621/LC60LE830U_manual.pdf
Jan 10, 2016 | Sharp Aquos LC40LE830U 40-inch 1080p 120Hz...
How do I change the menu to place full size picture on screen?
There should be a button on the remote called "aspect ratio" or "zoom".
Mar 07, 2015 | Akai CF2791 27" TV
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way...
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Aug 23, 2011 | Vizio 42 in. LCD TV
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
I have a toshiba 39"
On the TV remote there will be a button labeled ASPET or PICTURE SIZE or RATIO or ZOOM. Press that button while pointing the remote at the TV. Press it repeatedly until the desired picture size is acheaved. Not the cable remote but the remote that came with the TV.
Dec 26, 2010 | Televison & Video
Picture to large for screen
hit your aspect button or fomat button on your remote it will adjust size of picture also verify cable box aspect ratio
May 08, 2009 | Televison & Video
THE PICTURE IS OUTSIDE THE FRAME
you have to ajust the zoom...or aspect ratio...usuallly there's a one touch button, or go into the menu,then to picture settings..You should be able to adjust it there
Oct 23, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My screen had gone out fit its expanded and now its out of view
Screen size selection sometimes called aspect ratio--Check each menu/page selection to gain understanding of each function/feature.Consult owner/operator manual.If not available,WWW-- Akai Owners manual.
Oct 05, 2007 | Akai CF2791 27" TV
Picture size is always too big. No matter what the zoom setting or display setting, the image borders fall outside the screen. AKAKI tech support tel # is diconnected.
there are only normally 4 options for picture size, 4:3, 16:9, 16:9 zoom and auto, unless you are using High definition. Any other settings should be found in your cable reciever box as the picture size can be altered in its settings also.
Jul 30, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
295 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
