Question about Yahoo YHT-630 System
Y MESSENGER APPLICATION ERROR
YAHOO MESSENGER APPLICATION ERROR. i CANNOT OPEN MY Y MESSENGER. THIS STARTED WHEN I INSTALL A **** BLOCKER, PICBLOCK. PLS. HELP!
  • 258 Answers
Use system restore to roll back to a date before you installed it
Windows XP
Start --> All programs --> Accessories --> System Tools --> System Restore
Restore my computer to an earlier time
Click on the date you installed the **** blocker over to the left
on the right click on the point at which you installed and then click next, it will restore you pc to the point before it was installed
then continue
Make sure you are patient and do not force the pc to turn off with the power button, it will not change any of your files just the windows os
If it\'s vista the just type system in the search box and "system restore" will display above
Posted on Jan 31, 2009
Yahoo messenger will not even attempt to come on. All I get is a window that says YahooMessenger.exe Application Error Application faied to initialize properly(OxcO150002)
The error clearly says that the application is having problem so it couldn't be opened or run. Your only option to repair the Yahoo! Messenger or to re-install it (both a more or less similar). First of all, download the yahoo messenger and then install it, once everything is done correctly, it should work properly.
Please follow this LINK for the instructions on how to download and install it. Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 27, 2011 | Yahoo Messenger
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Yahoo messenger.exe - application error when i need to open my yahoo i received this error plz help? Yahoo messenger.exe application error 0xc150002
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Jan 27, 2011 | Yahoo Messenger
VAIO® VGN-CR120E/L PC Notebook: yahoo mesg not opening.what shld i do now?...
Yahoo messenger Application will not open if it is not installed correctly or due to corrupted registry or due to any Application conflicts.
You will need to uninstall and re-install the Yahoo Messenger Application in the Computer to resolve the issue.
  1. Please click "Start", Control Panel, and Programs and Features
  2. Under Programs and features category, please click "Uninstall and program"
  3. The, please select the "Yahoo Messenger" application and click "Uninstall" to remove the Program from the Computer.
  4. After that, please download the Yahoo Messenger from this link.
  5. Then, please install it in the Computer.
  6. This should fixit
Good luck..
May 16, 2010 | Sony VAIO VGN-CR120E Notebook
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
Cant open yahoo messenger
Hi! This error code relates mainly due to your action due to upgrade / re-install / repair of windows XP and to avoid this reinstall XP SP1a [service pack 1a] and immediately restart the system. have fine in all applications
Dec 21, 2009 | Yahoo Messenger
Installation of yahoo messenger error
I think you will need to upgrade your windows installer version.....download it from Here run it and now try ...hope it will work...Good Luck
Sep 25, 2009 | Yahoo Messenger
I can't install yahoo messenger
Uninstall the yahoo messenger program you have now and try dowloading again. Check your security settings, pop ups and spam blocker, it might not be alowing everything to download properly.
Jun 01, 2009 | Yahoo Messenger
Yahoo messenger problem
you might have installed third-party plug-ins, audibles or emoticons on your yahoo messenger. these programs are automatically loaded everytime yahoo messenger starts. they work fine, not until you reinstall yahoo messenger or upgrade it to a newer version causing an internal error when they are loaded. first, remove/uninstall all these programs from the add/remove programs in the control panel, be very careful when doing so and be very sure of what you are removing. then uninstall yahoo messenger. if error still occurs during the uninstallation process, you haven't removed every program/emoticons/plugins connected to your yahoo messenger. when uninstallation is successful, restart your computer and then delete the yahoo messenger folder in the programs folder on your system hard drive. then you can reinstall yahoo messenger before adding/installing your emoticons or plug ins again.
Oct 01, 2008 | Electronics - Others
Yahoo YHT-630 System Logo
76 people viewed this question
Top Yahoo Audio Players & Recorders Experts
micky dee
Kolbrun...
Computer Links
Are you a Yahoo Audio Player and Recorder Expert? Answer questions, earn points and help others
