Question about Adobe InDesign
Loose line and tight line problem
While doing the pagination how to avoid loose line and tight lines. In this case any special plugins avilables. please solve this problem.
Thanks
veera
What is fatal error 762
Trying to test this plugin on XAMPP localhost test site. Nothing shows up so I looked for errors and found this: Warning: require_once(C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow): failed to open stream: Permission denied in C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow\blip.php on line 762 Fatal error: require_once(): Failed opening required 'C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow' (include_path='.;C:\Program Files (x86)\xampplite\php\PEAR') in C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow\blip.php on line 762 --------------- The code on line 762 is the require_once, but here's a few lines before // attempt to talk to WordPress $blog_header_path = preg_replace("/wp-content\/.*/", "wp-blog-header.php", getcwd()); if (file_exists($blog_header_path)) { require_once($blog_header_path); }
Feb 12, 2015 | Office Equipment & Supplies
The fuel lines in my Ozito 25.4 cc 305mm bar chainsaw are perished, how do I replace them?
Chainsaw fuel lines are specialized hoses that either need to be replaced with TEFLON hoses of the same diameter, or the specialized rubber hoses that are resistant to gasoline and other chemicals. You should ask at a hardware store and make sure you get a hose that fits TIGHTLY into any holes on the gas tank, and also snugly fits over ant incoming metal or brass lines going into the carburetor.
Oct 18, 2014 | Garden
How to change the Pipe Flange Gasket / Seal on 1996 olds ciera 2.2
drain the fluid in the pipe,disconnect connection,remove old gasket avoid to trap in the line clean the surface ,apply thin lyer of gum ,place the gasket on the gum tight the connection avoid over tightness.
Jul 09, 2014 | 1996 Chevrolet Cavalier
How do i remove the transmission coolent lines from the transmission?
I would say yes..the back crossmember needs lowered..and a special open wrench is used to remove the lines..fluid will bleed out of them also..
Dec 30, 2013 | 2000 GMC Sonoma Extended Cab
How to replace crimped fuel lines
this could be a seal and not too bad to replace.
there is a special tool for removing the fitting. make sure you understand how it works to avoid problems.
the fuel line has to be bled down so that you don't get sprayed
when separating the lines.
check the lines for bent flanges and for seals.
replace as necessary.
install the new seal with the special tool it looks like a spring.
then get out the racing tires and have some quality time.
Feb 26, 2013 | 2003 Chevrolet Express
Web page errors
if you're using IE8 try the compatibility view,
Make sure that the page displays correctly within ie7 or ie6.
Let me have some feedback
Regards
GeWiz.
Jul 21, 2009 | Microsoft Internet Explorer 8
Homelite xl-175 chain saw no prime
As long as the line fits tight so its not sucking air you should be ok.. try changing out the plug if its old. Clean out the air filter too.. But the line should be ok as long as its tight..
Jul 10, 2009 | Garden
Transmission oil lines leaking
The lines have holes in them? Or are they just leaking at the connections? If just the connections, then all you need is two wrenches of the correct size. One on the permanent fixture nut like the radiator or the transmission, and the other wrench goes on the line. After removal, clean the threads, and apply some teflon tape and reassemble. tight is tight, and too tight is broke (stripped).
Nov 18, 2008 | 2006 Chevrolet Silverado 3500
Open Questions:
Computers & Internet Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
