Question about Kohler Model 7202: Drain For Purist® Baths - Polished Chrome
Bathtub Will Suddenly Not Drain
Suddenly the drain hole in the tub in my guest bathroom does not drain. The stopper moves up and down, but it will absolutely not drain a drop. I have no idea what happened. I just went to rinse it for guests coming tomorrow, as somtimes there are dead bugs in it after a while, and it just will not drain. I washed the tub 4 weeks ago and it drained very normally and no one has used it since. This is very strange. I stuck a plastic bendable stick down there, with barbs on it, and it went in and nothing came up. Can anyone give me a clue as to what may be wrong? The trap is made by Kohler, but I have no idea the model and I have to put somthing below or it won't get posted, so ignore the model below please.
  • 1 more comment
  • swetepi Jan 31, 2009
    I used a plunger and on the second push it unclogged. Thanks.
  • odlm2006 May 14, 2009
    i have tried every drano known and still have the same problem, my only guess left is that the drain plug does not open enough because the handle seems to be stuck. do i have to remove the whole tub? i also live in second floor, no basement to deal with....
  • Ron Krysiewski May 11, 2010
    Is the stopper in the tub itself? "Can you actually see the stopper go up or down in the tub". Are you in a cold area of the country? "Where it could freeze?
  • 33 Answers
Get a little draino and pour some down. Be careful, don't pour it to fast!
Well Done A+
Posted on Jan 31, 2009
  • 373 Answers
Tyr and use a plunger
it probaly has a lot of hair in it.
I do mine every couple month
Gurgling in the bath tub when toilet is flushed
follow this steps and fix it. God bless you
lear a clogged (not stopped) sink or bathtub with a plunger:
  1. If you have a dishwasher, pinch off the rubber dishwasher drain hose that leads to the garbage disposer using a clamp or locking pliers. If clearing a bathtub, remove the drain stopper and cover the overflow opening with a wet rag.
  2. Remove the sink basket or tub stopper and clean any debris from the drain opening.
  3. Fill the sink or tub with sufficient water to cover the plunger cup, usually about 2 inches. If you are working on a double sink, seal the other sink with a stopper so the plunger can create a vacuum.
  4. Set the plunger on the drain opening and repeatedly pump it up and down, then pull away sharply to dislodge debris. Repeat if necessary.
  5. Turn on warm or hot water to flush loosened debris from the drain.
  6. If the clog remains, use an auger (see below) or an expansion nozzle (see below) to clear the drain.
Clear a clog using an auger:
  1. Remove the stopper or strainer. If unable to do so, disassemble the drain trap (see below) and feed the auger directly through the pipe. Make sure you have a pail and rags nearby in case of a water spill.
  2. Release the setscrew on the auger and begin feeding the cable into the open drain.
  3. Once the auger tip hits the clog, set the screw and crank the auger clockwise to break up the clog.
  4. Continue breaking up the clog and moving it down the drain line with the auger. Once there is no more resistance to forward motion of the auger, stop and carefully remove the auger.
  5. If the clog can't be moved, continue twisting the auger to possibly snag and retract the clog.
  6. Once the clog is cleared, flush the drain with boiling water.
Nov 04, 2013 | Plumbing
Bathtub drain plug
It should be easy. You should be able to unscrew the stopper and take it out. The part of the drain that sits inside the tub screws in to the drain under the tub. It takes a special tool to remove it but you can use either two screwdrivers or is the opening is big enough the handle of your pliers and put them in the drain. If you look inside the drain there are two or three braces that go across and that is where you need to put the pliers or screwdriver in to get it to turn out. You can either get a new gasket or some plumbers putty and repair it. I hope that helped.
Oct 03, 2017 | Maax Home
How does the lift and turn stopper come out so we can clean plugged drain?
  • Push the stopper down to fully seal the stopper against the tub drain.
  • 2
    Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
  • 3
    Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
  • 4
    Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
  • 5
    Pull the stopper out of the tub by lifting it by the shaft.
  • Mar 12, 2011 | Maax Soprano II: One-Piece Shower Module...
    The problem is my bathtub won't drain.
    on most applications, where the lever for the stopper is located, mounted just under the faucet, also serves as the overflow for the tub: unscrew that plate and then you can pull the stopper linkage out. maybe you have a bunch of gunk (hair, etc) blocking the drain. once you have the entire linkage out, boil about a gallon of hot water and pour it down the drain; immediately follow with HOT tap water; if it drains, GREAT, if it doesn't, just let the HOT water sit there for a few minutes; then get your hand plunger and go to work. be sure to block the overflow hole (where you took the plate off) with plastic so that when you are working the plunger, you get good suction.
    Apr 20, 2010 | Moen Home
    Drain stopper in the bathtub has come off how do you reinstall when the stopper turns with a knob on the tub
    the stopper just sits in the hole. When you turn the knob the cable operates the piece that raises and lowers the drain plug. The weight of it and the suction of the water is what seals it....provided the o-ring is good on the plug.
    Oct 12, 2009 | Home
    Bathroom tub drain clogged
    If you have a popup/ plunger type drain stopper controlled by a lever at the overflow, then, yes, it would be a great idea to remove that. They commonly add to drain problems.
    Remove the two screws at the overflow plate (the one with the lever for stopping the water). Be careful that the gasket between the tub and overfow does not fall out when you fully remove the screws. Pull out the stopper assembly. You may have to jiggle it somewhat. Clear your drain some more and run a little water in it. Then replace the stopper assembly, making sure to keep the overflow drain lined up as you screw the plate back in.
    You may consider replacing a lever stopper with a "twist and twirl" type.
    If you do not have a lever assembly then you may have to use a small hand held snake to clear out the drain
    Mar 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I installed a new sink and pop up drain assembly. But the drain drains very slow because the stopper does not go high enough. I have tried adjusting the pop up assembly.
    make sure that the piece going in to the drain that moves your stopper up and down is all the way in the hole on the bottom of the stopper once that is in hold the rod down so your stop is up then attach it to the piece attached to your rod this should solve your problem good luck
    Mar 11, 2009 | Belle Foret Bathroom Sink Faucet -...
    My bathtub will suddenly not drain
    you need to use a hand snake you have to push the debris past the s trap
    Jan 31, 2009 | Kohler Model 7202: Drain For Purist® Baths...
    Delta pull-up bathtub drain problem
    Hi Bigoz,
    Drop the drain plug down about half way and try turning it counter clockwise. If you get no resistance after a full turn you will probably need to cut or break it out. If the pin is missing I'm guessing this is what you'll have to do. This answer assumes you have a lift and turn style drain.
    Please ratre this response and Good Luck, Phil
    Jan 01, 2009 | Delta T13420 Chrome Classic Single Handle...
    Kohler Model 7202: Drain For Purist® Baths - Polished Chrome Logo
    542 people viewed this question
    Top Kohler Plumbing Experts
    Paul Carew
    Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
