Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi VS 4552A
Mitsubishi VS-4552A Build Date Sept. 1994 There is a wide blue V in the middle of the screen top to bottom and blue-ghosted images during normal viewing. bring up the convergence adjustment screen, red & blue vertical adjusts fine, red horizontal fine, blue short and bowed, looks like a blue smile & the word blue bowed and fuzzy. That is it, otherwise my VS4552A mitsubishi build date Sept. 1994 Performs fine.
  • Danny Locke
    Danny Locke Jul 31, 2007
    Part of your answer you said:
    One of your convergence IC's has either cracked loose or burned out.
    Is this convergence IC on the convergence board?
    I removed the convergence board, checked it closely with a magnifying glass looking for a cracked soldier joint or just a dull soldier joint. Found neither one. The local repair tech wants $60.00 for a house call and diagnosis, I do not have a problem with that, but he said if it?s the convergence board it could cost as much as $400.00 to repair, that price makes me pucker especially when I read repairs costing much less. I tossed $750.00 at this Mit. 4 years a go having the power board? Repaired do not know if I can afford this tech. Would buying a used convergence board and installing it myself be a plan? Are there any adjustments to be made other than the test button and adjusting the convergence once the convergence board is replaced?
    Thank You for your response, Sconce
  • Danny Locke
    Danny Locke Aug 17, 2007
    Turns out my Mitsu. Has two convergence IC?s. One of our customers has an Electronics repair shop and he sold them to me at cost! I?ll be putting them in this weekend and will report the out come. This repair tech also said if these two IC?s didn?t totally fix my Mitsu. Not to panic. He said some times there are some resistors that will blow depending on the nature of the failure of the IC, he said they were designed to blow in order to save other parts. So I?m primed and ready to tackle this repair and I?m prepared for success and failure, short-term failure. Sconce
  • 398 Answers
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Posted on Jul 31, 2007
  • Mike Longo
    Mike Longo Aug 03, 2007
    Yes, the convergence IC's are the large black chips mounted on a large heat sink. The convergence IC's will have something like STK392-110 printed on them, although some sets have a metal bar across the front which blocks the numbers. The older projection sets had 3 smaller IC's, then they went to 2 larger IC's, and the newest ones sometimes have only one huge IC. It never makes sense to replace the entire convergence board, since it is only the IC that went bad. Ifg you do change the whole board then the set will probably have to be completely realigned from scratch, but if you change the bad IC then it will work fine. Look for those IC's, let me know what numbers are on them and sometimes they are even labeled with the colors they control.
I have a Mitsubishi Rear Projection tv (vs-50705). The picture shows a concave image on the top and bottom of screen and the edges go off the screen. I have red blue and green ghost images on the screen...
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Jun 06, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi vs-4552A
Call your local TV shops and ask if they have any 45 or 50" screens in the bone pile you could purchase. You should come up with something for a reasonable price $35 to $50 in good to excellent condition. You can cut down the screen to fit if you cant get the exact size. Good luck!
Feb 22, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi
you need to do self test first look in threads and also ctechnicians.com to get error codes.
Dec 30, 2007 | Mitsubishi VS-50611 50" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-4552A
This symptom seems to be a vertical Sweep fault cause what happens is theres a protection circuit in this set that activates when it sees theres no verticle sweep, it shuts off the picture on the set so that the tubes dont get lines burnt in the middle and become damaged. If you know your way around a TV set then you could locate the vertical output IC and resolder all its pins first as well as anything else in that circuit that looks like a cold solder connection. Then i9f it still does the same thing I would just replace the verticle output IC as well as the B+ supply capacitor off the flyback xformer for the sweep dirived power supply. Now if your not knowlegeable about these HI VOLTAGE circuits my advice would be do not attempt the repair yourself as you could get hurt and /or cause more problems with the set as there are no tubes in this set to test except the picture tubes. Contact Mits. at this #800-332-2119 or look in your owners manual for a contact #. Good Luck.
Jun 07, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
677 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
