Gateway FPD1530 loses image shortly after powering up.
Earlier, when I connected it to the running computer, the monitor gave the message ''out of frequency range.''
I shut the computer down using keyboard shortcuts while there was yet no image on the screen. As the computer shut down, the message ''It is now safe to turn your computer off'' appeared, the first image to show from the computer.
When I powered the computer back up, already connected to the monitor, monitor on, I saw the starting screens, and even my screen saver for a few seconds before it went black again.... When I turned it off and back on, the image would be there but then go away. The more times I did this, the shorter the time the image would remain. Eventually it wouldn't show any image, and again seemed to be dead.
  • 1 more comment
  • messerm Jan 31, 2009
    I'm running Windows ME. Thanks.
    It was set at optimal. I set it to 60Hz and connected the FPD1530. The only images I got were a brief flicker when I powered up the computer and a brief flicker on power down. When I turned the monitor off and then back on, I would see an image very briefly, just long enough to recognize it was my desktop. Then it went black.
  • danman1453 May 11, 2010
    What Operating system are you using?
    Problem Solver:
  • 11 Answers
Try booting into safe mode. press F8 while the computer is booting. see if everything stays normal. It should tell you that it booted into safe mode. Once there, change the resolution or the frequency of the display(also known as the refresh rate) by right clicking on the desktop and selecting properties. Once there, click the tab all the way to the right, it should give you color quality options and resolution options. At the bottom, there should be an advanced tab. Depending on our video card this menu can be different from others. Look in that new window for and option to change the refresh rate or the frequency. The value will be in xxx hertz. try setting it to 60 hertz.
Posted on Jan 31, 2009
Gateway fpd1530
If you have the appropriate cable to connect the output port of the computer to the input port of the Flat Panel TV every thing will be OK. For optimum performance you might have to install the drivers for the replacement flat panel.
Nov 01, 2013 | Gateway FPD 1520 15" Flat Panel LCD...
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
My gateway fpd1530 comes on then goes right back off any sugjestions on repair or is it worth it?
15? not likely.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor message will not go away....
On the monitor, press the [Menu] button.
Maybe more than once.
or.. unplug the monitor from the power outlet and plug back in.
Sep 30, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Jan 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
Nov 15, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
My Gateway FPD1530 will not turn on
replace c106 and c107. fixed 3 monitors back to back, all worked like new!
Aug 27, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Computers & Internet Logo
628 people viewed this question
David Payne
David Payne
