Question about HP Photosmart C3150 Printer
Want to scan several pages as one pdf document
I have a 12 page document I would like to scan as one pdf document with the scan feature of the HPC3150. It seems to save each page as a different document. If I were scanning to OCR it would let me do multiple pages, but I can't find a way to do it if I want to make a pdf.
This document was created by someone who doesn't use a computer, so saving it as one document is not an option. I have a pile of paper pages, and I want to make a single pdf out of the whole thing.
  • 71 Answers
OCR to Microsoft word ,then
You can find a software tranfer like DOC word file to PDF file.
http://www.doc2pdf.net/
http://www.pdfonline.com/
Posted on Jan 31, 2009
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
What is adf
Hello!
An automatic document feeder or ADF is a feature which takes several pages and feeds the paper one page at a time into a scanner or copier, allowing the user to scan, and thereby copy, print, or fax, multiple-page documents without having to manually replace each page.
Aug 15, 2017 | Office Equipment & Supplies
Whenever i scan to pdf, the output of images/graphics on the documents are not properly displayed. They are usually displayed as some funny-looking characters. for example, when i scanned a documents with...
You are scanning the pages in OCR (Optical Character Recognition) mode. This allows scanned text to be converted to (editable) text, and is more useful when scanning to a Word document for example.
If you just want to scan a page and archive it, look for a standard (non-OCR) scanning option, and specify PDF as the output format. If it's not available, you can just as well keep the pages in TIFF format, which also allows for multiple pages.
Also, if you have MS Office, there's MS Document Imaging tool included, that allows you to scan to MDI multi-page documents.
If however you want the page OCRed, I don't know which software is included with your scanner, but generally you must investigate the OCR settings to find an option to scan a page with text and images, instead of text only.
Some OCRs require you to select areas that contain text, leaving the rest as pictures, other do it automatically.
If you cannot make friends with your software that's bundled with the device, I would suggest looking for FineReader. Even an older version of FineReader is far superior to any other OCR software I've seen.
Good luck
Oct 18, 2010 | Computers & Internet
Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Mar 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Sep 14, 2009 | Brother Multi-Function Center MFC-240C...
I have a 10 page document I would like to scan as one pdf document with the scan feature of the HP officeJet J6410. It seems to save each page as a different document. If I were scanning to OCR it would...
scan in all the pages and search the Internet for a DPF creator software. or you can go to adobe.com and get the PDF creator (no free) that should enable you to save the document as one PDF file.
Mar 30, 2009 | HP Photosmart C3150 Printer
Try OCR Terminal,which is an online OCR service that converts scanned images into searchable text. Register an account and you can convert 20 pages for free every month.
Have a try and hope it helps.
Mar 30, 2009 | HP Officejet J6410 All-in-one InkJet...
I would like to scan several pages and have it save as one document. Currently each page is a separate document
thanks for using fixya!!!
Just check the setting and instead of using JPEG select PDF file, to save your scanned documents.
Regards! if you need anything more, let me know.
Mar 09, 2009 | Brother MFC-7220 All-In-One Laser Printer
Scanning several pages and saving as one document
Try this....
Scan your multiple pages to an image file, like .jpg, I know it's tedious, name them (optional) by page number, put them into an empty folder.
When you're done with all the scanning, open the folder, select all of them, open with: Preview.
Now, you should see one page, with a side bar containing all of the pages. (If they're not in order, you can drag and drop within the sidebar to reorder.) Select all of those (Or Command A)
Command P (Or Print)
In this window, you should see page one, and below that, make sure it says "Page 1 of XX"...this way you know you got 'em all, and it's your final opportunity to page through them all by clicking on the little arrows to make sure they're in the right order.
Click the PDF button
Save as PDF...
See if that helps
Jan 15, 2009 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart C3150 Printer Logo
633 people viewed this question
Seeker5211
Seeker5211
