Question about D-Link DI-704P Router
D-link router DI-704P
My router is blocking access to my bank's website
  • AUDRA O'HARA Jul 30, 2007
    Since installing a new computer and going from my wireless router to this hard wired router, I have had this problem. I just found out today that it is the router after troubleshooting with my bank, Dell and Optimum Online.
    President:
  • 2,961 Answers
Its unusual for a router to block anything outgoing it's normally incoming that gets blocked. Sometimes a Bank will not allow access if your system has spyware or trojan programmes running, so do an anti virus scan and antispyware scan. Also check that the content advisor is not set too low in internet explorer>tools>internet options>content tab>content advisor.
Posted on Jul 30, 2007
Guide on how to use the DI-704P router to connect to other computer
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 13, 2011 | D-Link DI-704P Router
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
I use the D-Link DI-704p router for an ethernet Lan with 8 Macs. Fast in the morning, horribly slow up/downloads in afternoon. Output runs at half speed of input from provider when tested in afternoon.
access your router with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to wi fi advanced then check signal channel type 4 , 6, 11 are working fine try 1 by 1 theses channel then check.
Set channel which give most high speed.
When you set channel always save settings then restart computer and router both after save settings then check.
Thanks for using fixya.
Jul 28, 2009 | D-Link DI-704P Router
D-Link DI-704P as wireless
Yes, you have to. The router model mentioned is not a wireless router, not unless you have other network device there that transmits wireless connection such as a wireless access point.
Jul 05, 2009 | D-Link DI-704P Router
How to configure DI-704P router using port forwarding
Check the reversion number on the bottom of your router.
General instructions for port forwarding are here.
If you need more specific details for a certain application, go from here. (You will have to scroll way down to find the D-Link section)
Dec 19, 2008 | D-Link DI-704P Router
Remote Desktop Connection on DI-704P
did you open TCP port 3389 on the router, and assign it to your computer? Remote desktop requires that port.
Mar 29, 2008 | D-Link DI-704P Router
Add di-704p to an existing network
What you want to do should be quite easy:
1. Just connect one of the LAN ports of the DI-704P to a LAN port of your WRT54G. Try using a standard network cable. If the port status lights does not turn on on both sides when you connect the cable, use a "crossover" cable. Important: leave the DI-704P WAN port empty.
2. Disable the DHCP server on your DI-704P, your WRT54G will be the DHCP server.
3. Assign a static IP address to you DI-704P, different from your WRT54G. Example, if your WRT54G has 192.168.2.1, you may assign 192.168.2.4 to your DI-704P. Make sure that the IP address you assign is outside the DHCP range configured in your WRT54G and that the subnet mask is identical on both.
You will then be able to use your print server from any wired and wireless computer and the remaining LAN ports both on the WRT54G and DI-704P.
Feb 18, 2008 | D-Link DI-704P Router
Online web configuration
For the DI-704P (Revision B) you will need to download and install the Java Plug-in for your Operating System. To download and install the Java Plug in now click the link below. Windows XP, Me, NT, 2000, 98, or 95 and Internet Explorer - http://java.com/en/download/index.jsp An alternative is to upgrade your browser to the following: Internet Explorer 5.5 or higher (with SP1) Internet Explorer 5.x (Mac) Netscape 6.0 or higher Mozilla 1.2.1 (5.0) or higher Firefox 0.8 or higher Opera 6.0 or higher Safari (with Java 1.3.1 or higher) Camino 0.7 or higher
Feb 16, 2006 | D-Link DI-704P Router
D-Link DI-704P Router Logo
78 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
