Question about HP Pavilion DV4000 15.4" LCD LEFT AND RIGHT HINGE SUPPORTER - 403921-001 (403921002) CD-ROM Drive
Hinges too loose on my hp dv4000
Right hinge is too soft whivh leads to creakig and shaking of the scrren
  • ganzey Feb 21, 2009
    screen wobbles, i think hinges are bad, how do you replace them???
    Problem Solver:
  • 5 Answers
You LCD hinge weared and teared too hard. So these is a interstice on your right hinge. You need a new hinge. You can find the hinge on ebay. and below is a replace manual.
h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Posted on Aug 18, 2009
I have a bathstore euro mono soft close seat. The hinge has come loose one side and needs to retightened. However, I cannot remove the seat from the hinge as the release button will not release the hi
Try using a knife to slide in the under-part of the release button and pop it off. If that doesn't work, you might have to brake it.
Oct 10, 2014 | Home
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
Miele classic h 383 b-cat Oven door will not seal properly. Checked seals and cleaned around hinges. No obvious signs Help Thank you
SPRAY HINGE WITH WD-40 AND SEE F THERE ARE ANY SCREWS OR BOLTS AT HINGE THAT ARE LOOSE OR THE HINGE IS BAD,GRAB IT BY THE HINGE AND SHAKE TO SEE IF IT IS LOOSE.THE HINGE PART THAT GOES INTO OVEN THAT YOU CAN NOT SEE COULD BE LOOSE OR ENLARGED TO MAKE IT NOT LINE UP.
Nov 17, 2012 | Ovens
Compaq Presario CQ50 notebook screen goes fuzzy when opened to a certain angle (about 90 degrees). Wires being pinched at the hinges? If so how do I go about repairing this?
it sounds like you've damaged the cable that goes from your graphincs card to your screen or when you move it to 90degrees it's disconnecting. it's usually caused by someone opening the laptop and not putting the cable back in the right place, or loose screws in your hinges or a broke hinge. there are plently of videos showing how to open it up. follow one of them and make sure your wires are sitting in the right place, you don't have loose screws and the hinges aren't broken.
Jan 13, 2011 | HP Compaq Presario CQ50-110US Laptop
How to fix broken hinges
The hinges needs to be replaced. These WEB sites provide parts and instructions to assist you.
Replacing Display hinges http://www.laptopparts101.com/display-screen-hinges/
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Apr 01, 2010 | HP Pavilion dv4000 Notebook
Left hinge busted
Dunt open and close lcd too muh otherwise it will damge your lcd cover and lcd bezel than it will cost u more. Remove all lcd screw cap and remove screws than slowly pull out lcd bezel and check is really hinges is gone or screw is loose. For Key u have to check it that any of latch of behind key is broken or fine. If its fine than just put that parallel to other keys and press it. it will seat back on jumper.
Jul 28, 2009 | HP Pavilion dv4000 Notebook
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Replace hinges on a HP dv4000 laptop
Don't worry. HP have a repair manual. You can see the manual firstly.
Hope this can help U
Jan 14, 2009 | HP Pavilion DV4000 15.4" LCD LEFT AND...
Hp nc4000 broken right hinge
there are lots on ebay for the pair usually between £10 and £18depending how long you want to wait also its a pretty easy job only tricky part is getting screen fascia off easilly!! behind the rubber stopper on screen fascia you will find screws and voiila your half way there!!
Dec 25, 2008 | HP Pavilion DV4000 15.4" LCD LEFT AND...
Computers & Internet Logo
379 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
