Question about Toshiba TE2100 Notebook
Display getting distorted and goes white blank at times
I hv been using Thoshiba TE2100 for the past three years without any problem. Now the display gets distorted with jerky lines and losses the sync completely. Some time it goes balnk white. I hv to forcefully turn it off by holding the power on button on the laptop to shut. When i start again it works and same problem after some time. I observed alos that when I tap near the display it settles down some time. May be a loose connection? Pls. help me on this one.
  • ganapathy kumar Jul 30, 2007
    I am an electronic engineer and can open the laptop and service componet level.
  • ganapathy kumar Aug 31, 2007
    The actual problem is the CGA card connector which sits on the mother board. There is a loose connection, but this cannot be repaired. Either the card or the mother board has to be replaced.
    Thankyou for your suggestion, your site is of great use for guys like me who want to fix problems themselves. Thoshiba service is a loot.HCL ( a dealer for Thosibha in India) is changing Rs.2000/- or $45/- for a cable connector.
  • 624 Answers
It could be a problem with an internal connection. A quick test and perhaps even fix would be to grasp the right and left sides of your display while it is on (displaying the offensive lines) and gently twist like you were wringing out a towel. Again, and I emphasize, gently using only a couple of ounces of force. Watch to see if the lines disappear, get worse of make the screen flash or change. If you do then its likely cause is the connector from the LCD panel to the electronics has oxidation or a loose connection. If you?re lucky the flexing might even fix your problem, if not you will have to take it apart to find out exactly what is going on.
Posted on Jul 30, 2007
On low volume using the clean channel the sound is great but as soon as you get to about three or more the sound gets a bit distorted,the amp is the fender hot rod deluxe, ithort i may had blown the...
try a differrent speaker of suitable wattage and ohmage (displayed with a number next to a ? symbol on the back of the speaker),
or
remove the original amp speaker and gently push in and out on it, checking for uneven resistance or scratching. the speaker should retract and return smoothly, without any scratchiness or uneven resistance from within, and if there is any of this scratchiness or uneven resistance from within, the speaker is likely damaged from too much wattage or distortion.
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
My TE2100 now asks for a HDD password on powerup.
there is virus attach on you hdd
changing of hdd is only solution
Jul 27, 2009 | Toshiba TE2100 Notebook
N72 screen goes blank
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is the solution! Please vote!
May 17, 2009 | Nokia N72 Cellular Phone
Screen gets distorted and turns white
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Apr 25, 2009 | Samsung SPH-m520 Cell Phone
N72 white display
My N72 (Nokia) phone’s display shows blank when switched-ON. Blank in the sense means that the display lights are ON, but no images in the display. Sometime the dispay comes and goes. In addition, the phone is not ringing or can’t make calls. Can anybody help me?
Oct 23, 2008 | Nokia N72 Cellular Phone
Problem with display of Nokia 6600 mobile
my nokia6600 occurs same problem
when i switch off and then switch on the phone then display comes for the time i am using the phone. As i left the phone for sometime without pressing any key it again goes to that white screen mode..but phone is functioning .plz help me to rectify the problem.....
Jul 14, 2008 | Nokia 6600
Toshiba TE2100 blank laptop screen
Try holding the Fn key down and then press the F5 key a few times, waiting a few seconds each time to give it a time to switch between display modes.
May 29, 2008 | Toshiba Tecra 8100 Notebook
Freezing then blank screen
Have you tried pressing F8 on boot-up and log into safe mode under administrator, no password, and right click on any empty space on the desktop, left click on properties, left click on settings, select a lower resolution,( e.g. 1024X768 ) select apply, select ok, reboot, log in as normal
Mar 26, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Toshiba TE2100 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
