Question about Vivitar ViviCam 3785 Digital Camera
Vivitar vivicam 3875 wont turn on with new sd card
SOURCE:
beergut707
  • 79 Answers
SOURCE: SD card for Vivitar ViviCam 4000
hi there
i'm afraid the biggest card you can use on this camera is 512 mb, which should give you about 150 pics at medium quality.
if this was helpful please leave feedback
beergut707
Posted on Oct 19, 2008
karan4aaki
  • 68 Answers
SOURCE: if your VIVITAR VIVICAM 3720....
you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Posted on Mar 10, 2009
SOURCE: Vivitar ViviCam X014 will not turn on. Memory
Buy a real camera. X014 is cheap and has a foggy cheap lens. It will never take a good quality picture. It is a waste of a 10 megapixel chip!
Posted on Aug 21, 2010
SOURCE: I just bought a Vivitar ViviCam T027 camera. The
Hi there
Funny, I recently bought the exact same model. The answer to your question is simple (that's the good news!)
A long time ago, when these small SD Cards first appeared, they were limited in capacity from 128 Megabytes (MB) to a maximum capacity of 2 Gigabytes (GB).
To enable the same size card to store a greater capacity, a new specification had to be created. This new spec. was SDHC, and allowed the cards to store from 4 GB up to 32 GB.
The confusion arises because people still refer to all these cards as 'SD cards' when the higher capacity cards should really be called 'SDHC' cards.
Your camera will accept standard SDHC cards. Just make sure you don't order 'mini' cards which are much smaller in dimension.
Hope this clears up the confusion.
Phill R
Posted on Oct 19, 2010
Testimonial: "You explained it perfectly. Your right, Vivitar caused the confusion by referring to an SD card rather than an SDHC card. Thanks for your help."
  • 11967 Answers
SOURCE: The Vivitar ViviCam X014 keeps stating Memory
You have one or more pictures on the camera's internal memory and it won't let you use the memory card. With no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. After that, your card should work properly.
Posted on Dec 14, 2010
My vivitar T028 camera wont turn on
i also have a Vivitar ViviCam t028 and i just changed the batteries and it wont turn on i was just about to empty the memory card but it wont turn on so i can't i don't know what's wrong with it.
Dec 25, 2012 | Vivitar ViviCam X327 Digital Camera
When i put a sd card in my vivicam T027 it says the card is full
What kind of card is it? If it's an SD card, try sliding the little slider on the side of it to unlock it, so it's not read-only
May 30, 2012 | Vivitar Vivicam T027
The SD card from my Olympus camera does not fit into my new ViviCam 5022. Does it have to be a certain brand of SD card?
Is it actually an SD card? The Vivicam 5022 accepts SD cards up to 8GB (which means SDHC as well), but many Olympus cameras use an XD card, which is quite different. SD and SDHC cards are all the same for fit, regardless of brand.
Nov 22, 2010 | Vivitar ViviCam 5022 Digital Camera
New sd card says full
Check and make sure the SD card is in all the way, it should make a clicking sound when it's in all the way. I had this same problem with my Vivicam 8025. Hope this helps!
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Would like more picture capability . . .
Your Vivitar Vivicam 5385 accepts SD Card cards.The largest SD Card card you can use in your Vivitar Vivicam 5385 is 2GB.
This link will take you to an online store, the Panasonic 2GB SD card is £5.99 Delivered.
http://www.mymemory.co.uk/SD-Cards/Panasonic/Panasonic-2GB-SD-Card-%28Secure-Digital%29
Simply insert this into the slot on your camera and you should be good for well over 800 to 1000 pics.
Best wishes and hope this reply helps.
Mike.
Mar 02, 2009 | Vivitar ViviCam 3330 Digital Camera
Vivitar Vivicam 3715 can't format new 2gb SD card. Card OK!
What information is given in the manual ?
BTW, AFAIK, 2gb SD cards and 2gb SDHC cards are not interchangeable - do you have the correct one ?
Jan 13, 2018 | Vivitar ViviCam 3715 Digital Camera
hi there
beergut707
Oct 18, 2008 | Vivitar ViviCam 4000 Digital Camera
Vivitar
My Vivicam 4000 owners manual states that only SD cards up to 256 Mb are supported.
Feb 14, 2008 | Vivitar ViviCam 4000 Digital Camera
Vivitar ViviCam 3785 Digital Camera Logo
77 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
