Question about HP Deskjet 2460 InkJet Printer
Printer problem When I print my doc, the printer will print but the output is nothing. will appear in the paper...my cartridges are OK
  • 71 Answers
Can you try to reinstall your printer driver , print a test page ,double check,it is your printer issue.
Posted on Jan 31, 2009
Printer appears to be printing but nothing prints on paper
if your printing off a pc you need to hit print to activate
May 01, 2010 | Canon PIXMA iP90 Mobile Printer
Error paper output slot. the paper is jammed clear
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
Ash
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My printout is not sharp
Step one: Print a cleaning page using the control panel
You can clean the interior of the product by using the Cleaning mode function on the product control panel. To do this, follow these steps:
1. From the control panel, press Setup .
2. Use the arrow buttons (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01393346.gif ) to select Service , and press OK .
3. Use the arrow buttons (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01393346.gif ) to select Cleaning mode , and press OK .
4. When prompted, load plain letter or A4 paper into the input tray.
5. Press OK to confirm and begin the cleaning process. A page feeds slowly through the product.
6. Discard the page when the process is complete.
7. Wipe the paper width guides and the paper path with a dry, lint-free cloth.
Step two: Clean the scanner glass and the cover
1. Turn off the product, disconnect the power cord from the product and the wall outlet, and then wait for the product to cool.
2. Open the scanner cover.
3. Gently wipe the scanner glass and the cover with a soft cloth or sponge that has been moistened with nonabrasive glass cleaner.
4. · Dry the glass and lid with a lint-free cloth, chamois, or a cellulose sponge to prevent spotting. Do not use paper-based wipes or tissues that can scratch the glass, or leave fiber residue.
5. · Close the scanner lid.
Step three: Clean the pickup roller
1. Push the release button, and open the print cartridge door.
2. Remove the print cartridge and find the pickup roller.
3. Release and remove the pickup roller.
a. Pull the small, white tabs on either side of the pickup roller outward.
b. Rotate the pickup roller toward the front.
c. Gently pull the pickup roller up and out.
4. Clean the pickup roller with a lint-free cloth, lightly moistened with water.
5. Allow the pickup roller to dry completely.
6. Reinstall the pickup roller.
a. Position the pickup roller in the slot.
b. Rotate the top of the pickup roller away from you until both sides snap into place.
7. Replace the print cartridge, and close the print cartridge door.
8. Reconnect the power cord to the product and to the wall outlet, turn on the product, and then try again to print.
* If these steps resolved the issue , you do not need to continue troubleshooting.
* If the issue persists , see the next solution.
Solution five: Check the driver settings
Try to resolve the issue by adjusting the driver settings.
Step one: Check the printer default
1. Open the Printer or the Printers and Faxes window.
o Windows XP : Click Start , and click Printers and Faxes .
o Windows Vista : Click the Vista icon (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01319360.gif ), click Control Panel , click Hardware and Sound , and then click Printer .
2. Find your product, and check whether it is selected as the default printer.
o If the product icon appears with a checkmark (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01854338.gif ), skip to the next step.
o If the product icon does not appear with a checkmark (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01854338.gif ), right-click the product icon, and select Set as Default Printer .
Jan 02, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Printer prints, but nothing appears on paper. Ink
if your printer is Canon, usually there are 2 possibility.
First one is the cartridge / head need replacement with a new one.
Second one is the main chip in the printer's board burned or damaged.
Sep 19, 2009 | Office Equipment & Supplies
Nothing appearing on paper when I am printing
on the cartridge there is a circuit if the circuit is faulty then the cartridge will not print.let there is plentty ink but due to faulty circuit it will not print.another problem is the printer driver is got corrupted so reload the driver and check out. also try giving out printer test page from pc and check out. if the circuit is faulty cartridge has to be replaced.
Aug 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
Canon i965 prints blank pages
Yes those printheads do go bad, they burn out just like a light bulb. If you emptied cartridges then the purge/cleaning assembly is working properly, and the only other option is the expensive printhead.
Aug 20, 2009 | Office Equipment & Supplies
Won't Print, copy or scan
Take the cartridge back out and reinstall it just to be on the safe side. If that does not clear up the problem, there is a very strong possibility that you have a faulty cartridge that needs to be replaced (it can be faulty even if it is a new cartridge). - Graye
Nov 02, 2008 | HP PSC 1410 All-In-One InkJet Printer
Lexmark X8350 jams (and other problems) after ink cartridge refill
You have a paper jammed in the path or there is something blocking the path, try to look inside carefully.
Apr 29, 2008 | Lexmark X8350 All-In-One InkJet Printer
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
CANON BJC-85 Won't print black...
Turn on printer, press cartridge button, remove cartridge. On left side of remaining cradle, unsnap the cradle, lift up and remove. Take the cradle to your sink, wet a paper towel, and GENTLY wipe the long print head with the wet paper towel. Then run a small stream of clear cool water through the cradle, from the round pad that your cartridge rests on, until the pad looks ink-free. Dry everything with tissues and a hair dryer set on low, replace cradle in printer, replace cartridge, turn on printer, press Resume until it beeps three times, which runs the deep cleaning program, and after the procedure is finished, your printer will print as new.
Apr 14, 2007 | Canon BJC-85 InkJet Printer
HP Deskjet 2460 InkJet Printer Logo
Ben Johnson
