Optimus lab 1100 turntable
I bought this years ago and have never opened it. I can't find the instructions. I want to connect it to my lenovo thinkpad and then listen to a vinyl record and ultimately copy to put on ipod or burn to cd.
I know very little about computers but once someone tells or shows me what to do I am usually ok
  • rainsfordcla Feb 01, 2009
    Thank you. I now have it set up but don't have sound on the pc.
    Can you suggest how I can get the sound through the PC?
    The turntable power output is swithced on and I've tried connecting to both the microphone and the headphones.
    Is there a program I need to open first or do I need software for the PC to input from the turntable?
What is the best recording software for the optimus lab 1100
Posted on Feb 25, 2009
    Brigadier General:
  • 5,158 Answers
Http://support.radioshack.com/support_audio/doc63/63393.pdf
Robert
Please take a moment to rate this solution thanks
Posted on Jan 31, 2009
  • Roberta Smith
    Roberta Smith Feb 01, 2009
    perhaps bump that up to a fixya... thanks
  • Roberta Smith
    should be hooked up to line in... it's the centre plug in on the sound card... make sure that is not muted in the sound control
My Optimus LAB 1100 is playing 45s ok but the 33s sound like the chipmunks
the turntable speed is incorrect
adjust with the speed control setting
many quality turn tables have bar codes around the outside edge and when viewed under a light those bars appear to be stationary when the correct table speed is set
It is a strobe affect in time with the frequency of the light
Dec 06, 2015 | Audio Players & Recorders
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
Connect optimus lab 1100 to macbook
The type of computer is not relevant. This turntable provides output at nominal "line level" and can be connected to your MacBook with a properly shielded audio cable through the audio input.
For best results, you might want to disable automatic-gain-control (AGC) in the "Sound" preferences pane in the "System Preferences" panel, and set the level manually such that the input does not overload.
As I mentioned above, the signal level is nominally "line level", and that can mean very different things depending on context. You might find that using a passive volume control (potentiometer) between the turntable and the computer's analog-to-digital converter can greatly improve the quality of sound.
Jun 20, 2014 | Apple MacBook Pro Laptop Computer with...
How do I replace needle on Optimus Lab 1100
The manual for the Optimus LAB-1100 can be found here: http://support.radioshack.com/support_audio/doc63/63393.pdf
Replacing the needle is on page 13. I did it and it was easy.
Cheers, Gordon.
Dec 18, 2012 | Audio Players & Recorders
I have an Optimus LAB - 1100 automatic turntable i was wondering how you burn your LPs onto CD
stopped working - i took turntable apart - the wires controlling start, stop & cue are loose. i don't know where to reconnect them.
Mar 10, 2009 | Audio Players & Recorders
Optimus lab 1100 truntable will not operate.
this is a belt driven platter. the belt is old and fell off. http://www.archive.org/details/Turntable_Belt_Installation
this link shows how to replace a belt, once you see where the belt goes thread a piece of string through the mechanism where the belt should go and measure it and contact them with the length. or measure total length of the old belt if still in one piece. figure about $14 for most belts.
Jan 24, 2009 | Audio Players & Recorders
Replacing needle
Cheers, Gordon.
Nov 24, 2008 | Audio Players & Recorders
Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Aug 07, 2008 | Audio Players & Recorders
How to remove platter on Optimus Lab-1100 Turntable
on the shaft in the center where the hole of the record goes there is a locking washer on it . you can carefully remove this with a thin knife of something similar . you may need to use a little force , it is on there pretty tight however it can be removed .good luck
Jul 21, 2008 | Audio Players & Recorders
Computers & Internet Logo
324 people viewed this question
David Payne
David Payne
