Question about Water Heaters
Water too hot on a Vulcon Freeloader Super 10
We have a Vulcan freeloader super 10 external hot water service and the water temprature is very high and dangerous with children.
How do I lower the water temp.
Thansk for any help you can give
  • Thomas F. Schneider May 11, 2010
    Gas or electric? Tank or tankless?
  • 34 Answers
Remove the cover and there should be a temp setting
Posted on Feb 08, 2009
To hook up gas, to an Vulcan 260 freeloader
best left to a pro . gas leaks cuase explosions when we certainly don't want one
Jan 21, 2015 | Water Water Heaters
Hi i have a vulcan freeloader super 10 the question i have is these no pressure in the tap or these not much water cames out when in use of hot water
Dave, is this a small electric heater for just one sink? Are all water supply valves turned on completly, at the heater and the house main supply line? If they are, and without a bit more info about how it is used, I'll give an educated guess. Please check your faucet aerator, the part right at the tip of the faucet where the water comes out. It is usually screwed in counter-clockwise. you may be able to unscrew it by hand, or with a small wrench. Most of them have very small flat areas on both side of the unit to use a wrench. .Look at it carefully when you remove it and you would find a screen and several other parts as you disassemble it, being cautious to lay parts out in the order they come out all the way to the last screen. One of the parts is a piece of plastic that has tiny holes around the edge, and they may have tiny pieces of debris that block the holes so water cannot flow properly. clean them out carefully by blowing or using a toothpick to ease them out of the way. when cleaned, along with the screens, reassemble in reverse order and re-install into the faucet. If it is completly clogged, you can replace it inexpensively at the hardware store or Lowes/home depot. take you's with you to identify the replacement. Good luck.
Nov 02, 2014 | Water Heaters
Vulcan freeloader 260 suddenly turns off after heating to temperature. Control unit was just replaced but still doing the same. I was told by another person it is the thermo couple but the fitter said
The thermocouple makes sense, if it does not send enough electricity to the control unit it will shut off. The thermocouple was probably moved when a new control unit was installed. Check to be sure the pilot flame touches the thermocouple, if not realign it else replace it.
Mar 25, 2014 | Water Heaters
Sime super 80.. Heating and hot water at the same time?
going off on a safety possible high temp unit needs service such a nozzle filter if oil or thermocouple if gas
Jun 16, 2017 | Water Heaters
We are getting a brown colour in our hot water from our Vulcan freeloader (assume this is where its from anyway). Is this a fixable problem or will we need to look at a new unit? The current unit is about...
unfortunately there is no fix other than replacing the tank, it has a lot of rust buildup inside over 18 years, which is a very long time for a hot water tank today.
Aug 30, 2011 | Water Heaters
Can I replace the pilot light on a Vulcan Freeloader 260 gas HWS?
Hello...how old is the unit? Today it is very common for gas appliances to have electric igniters instead of a pilot light. Unless you are familiar with gas controll/regulator valves I would not recommend trying this yourself. I believe it is more likely a faulty or dirty thermo-couple. Again , unless you are familiar with the opperation of gas supplies ,controls ,etc. DO NOT ATTEMP to do this yourself!!! Gas is very dangerous for the less than well informed! Call a service pro or speak to and ask for the assistance of a knowledgable friend.
Feb 14, 2011 | Water Heaters
My Mum has a Vulcan freeloader 260 gas hot water system and it appears that the pilot light has gone out. The only problem is I can't find where it is to test how to turn it back on. Can someone please...
Remove the access panel lower right hand side and locate the pilot light re-igintion push button. The instructions are pritnted on the back of the access panel.
May 18, 2010 | Water Heaters
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Water Heaters Logo
887 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
