Question about ASUS Eee 4G Notebook
LCD Erroe it was a rainy night my laptops lcd got wet...after 3 days it went white everytime i turn on my laptop..pls..help me...
    Genius:
  • 1,689 Answers
Some water got in to the screen and maybe some of the boards in the computer. It eventualy caused damage. The fix is to try the screen, connector and ribbon assemblies, and the display daughter board if there is a daughter board in your model. It is also possible that the mother board has a fault.
This type of fault can end up being expensive to service.
Jerry G.
Posted on Jan 31, 2009
My display doesn't work! I bought the phone for about a month ago and I just went back from a rainy day and the display just went white? What should I do?
I think there is some moisture between the LCD screen of your phone and the flex cable,which is hindering the transmission of images on the screen.
The solution to the problem goes thus';
1.Remove the back cover of the phone and take out the battery.
2.With the help of a credit card,running it though the edges of the phone,take out the top back panel of the phone.
3.Using a hand dryer,dry out all the panel of the phone,but ensure you don't take the dryer to close to the panel.
4.If the problem persists after this solution,it means the LCD screen is bad and definitely needs a replacement.
Good day.
Aug 21, 2010 | Sony Ericsson W760i Cellular Phone
I have a asus eee pc 100ha.. i had it last december of 2009.. just last night my lcd screen went black.. pls. help.. few weeks back, once in a while it will my screen has displayed liked there is a power...
when i turn my netbook on the lights turn on but the screen doesnt. I figured out that if i leave it running till the battery goes very low it will turn on.
Jun 07, 2010 | ASUS Eee PC 1000HA Notebook
HP Pavilion dv4ee LCD problem
u bought ur laptop in march 2009 and have 1 year warranty , i think u much take to brand hp to warranty, ur lcd have problem
Jan 16, 2010 | HP Pavilion dv4000 Notebook
TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
My laptop went to white screen every time when I on it. How to solve....my laptop -- aspire 4710z -- almost 2 years but it happened JUST it 4 mths.....
Hi..
Your problem are related with my laptop problem, but i totally fix it with my own. From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
1-laptop-white-screen.jpg Here’s an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose you using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I'm assembled everything back together and connected the original LCD, it’s still white.
In my case this problem is related to the LCD screen and it has to be replaced.
That's my laptop brand and model, and i am searching an image regarding about my problem. This problem are common to another brand.
Hope it may helpful for you!
Good luck
ICmanServer
Jul 31, 2009 | Acer Aspire 4720 Notebook
WET LAPTOP BAD CONDITION
You tried your best in performing the first step (Leaving it out to dry)
But actually it is posible that the heat of the sun couldnt reach into some parts of the laptop and that some components must have been aftected before you came to its rescue
Apparently water or moisture was still resident in some internal part of the Laptop and this would have conducted some little spike of electricity that might have destroyed some components while it was connected to the AC.The flickers on the screen is an evidence of a possible spike from water or moisture.
Get a technician to open up the Laptop completely. He has to take a good look at each component carefully and clean them up.
Yes theres a possibility of your LCD being damaged but the VGA Card should be tested first.
Your Laptop would definitely come back to normal but not until each component is checked properly
May 21, 2009 | Samsung lt150x3-124 15 in. Flat Panel LCD...
1997 Jetta 4 Doors Won't Start on rainy, wet and cold days
Damp is getting into your electrics. Spray all wires and disributor with WD40 after wet days or nights before trying to start it. That should cure it
Mar 30, 2009 | 1997 Volkswagen Jetta
My screen is flickering
firstly try reinstalling the video drivers, if that doesn't work either the inverter is ready to give up or the monitor connector has somehow worked loose from the socket
Nov 13, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire 5585 Laptop LCD Problem
You need to replace the inverter of your lcd screen.
Oct 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
ASUS Eee 4G Notebook Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
