How to Design a radio player in website by using javascript?
I want to design a radio bar which consists of play,stop,forward,previous buttons, etc by using javascript and H also.
Shafihot SERVER ERRROR Solution
How To Make Your Own Radio Station
Must HAVE Winamp (Any Version)
First, things First your speed has to be at least 256/64 kbps (which means Dial-up users, will have alot of latency, just dnt bother)
Second, your going to have to have a domain, an updated one with the current i.p active. (Could be anything e.g. My sig)
Now, Your gonna have to download the Shoutcast Files.
Go to www.shoutcast.com to get the files.
Ok After downloading these, installing Both of them in any order i dnt care. Go to START>PROGRAM FILES>SHOUTcast DNAS>EDIT SHOUTCAST DNS CONFIG.
Ok your gonna have to Configure it:
Go Down and where it says password: change (that means your gonna have to change it to whatever, make sure u remember)
The Portbase: change it to whatever port you want it
Maxusers: (lets be realistic here, dnt put in 10000, like NXS's radio station) your bandwidth has to be extremely good, if your cable, 50 user max is ok, ADSL should stay below 10 users, and T1 connections should do whatever tickles there fantasy.
Open winamp, RIGHT CLICK>OPTIONS>PREFRENCES>DSP EFFECT> and choose the NULLSOFT SHOUTCAST.
Go to OUTPUT, and then click on Connection, Through the ADDRESS, type your address which you have done through www.no-ip.com, PORT NUMBER, whatever u did in the EDIT.txt, and your password.
Then go to Encoder, and choose your quality of your music. Go back to OUTPU>OUTPUT CONFIG> YELLOW PAGES. this is your advertisemant information. dow hatever you like there.
Now Connect. to check that your Radio os on-line go to http://(your address that you added in the prefrence)
more detailes...
help
mail me shezrulezz@gmail.com
shezrulezz@yahoo.com
Posted on Jan 31, 2009
What is the main learning part of web developer and design?
Web developing and design is a good profession. To learn basic design you mast be knowledge about basic html, html5, XHTML, CSS, css3, JavaScript, jquery, plugins, wordpress, theme customization.now a days theme development is so much demand able in word web development. W3school is the place where you can take basic knowledge. In the Upwork you can bit for a good job in this profession. In Singapore web design development is so much Singapore Web Design Development Company Singapore
Feb 28, 2016 | Computers & Internet
Santai TD-V26 user manual
The device has an on/off toggle switch and four control pushbutton switches (left ro right) are:
1. Menu (FM Radio or MP3 Player) select
2. Play/Hold
3. Back/Previous
4. Forward/Next
Inputs and output are:
1. 1/8" External Source Input Jack
2. Micro SD Slot
3. Mini USB 5v External Power Input
4. 1/8" Headset/Output Jack
5. USB Memory Card/USB Cable Input/ (Right Side)
The Menu switch has two functions, MP3 Player and FM Radio as indicated by the display. If the Play/Hold switch is pushed in and held for a few seconds the radio will automatically sweep and put the available local stations in memory. The back and forward switches are used to select the desired station. The display indicates station channel number and broadcast frequency (MHz).
In the MP3 Player function Menu function the Play/Hold Switch starts and stops the player. Back and Forward switches select the previous or next track. Simple as that. The player automatically plays the next file if left alone unless the Play/Hold switch is pressed. The display indicates file number and play time. No other functions, like folder selection, were found. If a 5v dc supply is connected to the Mini USB connector the battery will remain charged and it can be used as a small table radio/player. No tests were made to see how long it would operate on its internal battery.
The sound is good and better than expected for a device its size. Enough sound output to hear it in any part of an small house (With some distortion of course). The volume is controlled by holding the forward or back switches in for a couple of seconds and it will switch to volume level control. The display is LED rather than LCD and easier to view. It is on continuously when the player is working with the charger attached.
Aug 23, 2012 | Santai TD-V26 Portable Mini Digital...
How do i get my twitter sidebar transparent?
hi there! :) here's how to make your sidebar transparent! just carefully follow the steps! :)
1.Log-in to the design section of your Twitter account using your user name and password (see Resources).
2.Copy and paste the following code, minus the quotation marks in the beginning and end, into the address bar of your browser: "javascript:document.getElementById("user_profile_sidebar_fill_color").value = ";document.getElementById("title_theme").innerHTML = 'Click The Save Changes Button At Bottom To Finish!!';void(0);"
3.Push "Enter" on your keyboard, then scroll down the webpage that loads and click "Save Changes." Your Twitter sidebar is now transparent.
Oct 03, 2011 | Twitter Tweets
I cant get my twitter sidebar to be transparent.
Oct 03, 2011 | Twitter Computers & Internet
How can i make my website more attractive without using any flash files Please visit to my website and give me suggestions http://essayservices.co.uk
Use jquery (an advanced form of javascript) to make this animated banner instead of flash, because flash contents are not preferred today for better search engine optimization.
Jul 28, 2011 | Computers & Internet
I want help in website design. My site is half complete and I just need to replace top buttons with a menu bar. I have bought the menu bar from graphicriver.net but I am unable to place it as it requires...
Hi, It would be difficult to help like this, but i can work with you to design your website. There will be very nominal charge for that. Please let me know if you want to give the project to me. I will not charge you until you are satisfied. Mail me at alokerdas@sify.com.
Nov 10, 2010 | Computers & Internet
Hello, you either have JavaScript turned off or an old version of Adobe's Flash Player. Get the latest Flash player. whats this?
You need this to play Video's on the net, like Utube etc. get it here, download and install. reboot, and next time you use your "Browser" you will be able to see videos that use Flash Player.
www.adobe.com/.../flashplayer/downloads.html - United States
Feb 11, 2010 | Computers & Internet
Windows Media Player has stopped working
Dermot Hi.Im Bj. You may have to go in and uninstall media player and re-insatll try this should work..Bj
May 17, 2009 | Microsoft Windows Media Player
Hi i am in some trouble please help me. actualy i would like to know that how i create color scroll bar and some dynamic coading of java which help me in website design Thanks
You should probably use javascript instead of java first. Then it should be relatively simple:
http://www.codeproject.com/KB/HTML/scrollbarcolors.aspx
Dec 19, 2008 | Computers & Internet
Computers & Internet Logo
526 people viewed this question
David Payne
David Payne
