Question about Microsoft Windows XP Home Edition for PC
Want to delete ms antispyware 2009
Keep getting messages from ms antispyware 2009 saying I have viruses. When I say I want to delete them, it says I have to purchase the software. This keeps happening and I can't get rid of it. It kicks me off of any internet site, with the continuous message. I ran my symantic scan, and it still was happening. I can't get rid of it.
  • Anonymous Feb 19, 2009
    i was able to get rid of ms antispyware 2009 but now my explore or firefox will not connect to my internet. but msn messenge will work
  • 79 Answers
Hi sounds like you have a malware. Which is a malicious software,it's a type of virus. I suggest you download malware bytes, install and run. Also dowload adaware. I have provided the links where you can download them. That should get rid of it. Don't forget to rate me. Thanks
http://www.malwarebytes.org/
http://www.lavasoft.com/products/ad_aware_free.php
Posted on Jan 31, 2009
  • 71 Answers
Can you try to delete in "Control panel" "Add and Remove Program" .
    President:
  • 2,559 Answers
Antispyware 2009 is the virus.
Follow all the instructions below
Antivirus 2009 Manual Removal Instructions Step 1 : Use Windows File Search Tool to Find Antivirus 2009 Path
  1. Go to Start > Search > All Files or Folders.
  2. In the "All or part of the the file name" section, type in "Antivirus 2009" file name(s).
  3. To get better results, select "Look in: Local Hard Drives" or "Look in: My Computer" and then click "Search" button.
  4. When Windows finishes your search, hover over the "In Folder" of "Antivirus 2009", highlight the file and copy/paste the path into the address bar. Save the file's path on your clipboard because you'll need the file path to delete Antivirus 2009 in the following manual removal steps.
  5. "Antivirus 2009" files can be found in the directory path(s):
%ProgramFiles%\AntivirusPro2009
%ProgramFiles%\AV9
%ProgramFiles%\Power-Antivirus-2009
%UserProfile%\Start Menu\Antivirus 2009
%ProgramFiles%\Antivirus 2009
Step 2 : Use Windows Task Manager to Remove Antivirus 2009 Processes
  1. To open the Windows Task Manager, use the combination of CTRL+ALT+DEL or CTRL+SHIFT+ESC.
  2. Click on the "Image Name" button to search for "Antivirus 2009" process by name.
  3. Select the "Antivirus 2009" process and click on the "End Process" button to kill it.
  4. Remove the "Antivirus 2009" processes files:
%PROGRAMFILES%\AV9\av2009.exe
AntivirusPro2009.exe
%PROGRAMFILES%\Antivirus 2009\av2009.exe
ieexplorer32.exe
AV2009Install[1].exe
Power-Antivirus-2009.exe
c:\WINDOWS\system32\ieupdates.exe
c:\Program Files\Antivirus 2009\av2009.exe
AV2009Install_880405[2].exe
AV2009Install_880405[1].exe
av2009[1].exe
AV2009Install.exe
Antivirus2009.exe
av2009.exe
Step 3 : Use Registry Editor to Remove Antivirus 2009 Registry Values
  1. To open the Registry Editor, go to Start > Run > type regedit and then press the "OK" button.
  2. Locate and delete the entry or entries whose data value (in the rightmost column) is the spyware file(s) detected earlier.
  3. To delete "Antivirus 2009" value, right-click on it and select the "Delete" option.
  4. Locate and delete the folowing "Antivirus 2009" registry entries:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{037C7B8A-151A-49E6-BAED-CC05FCB50328}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "75319611769193918898704537500611"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "ieupdate"
HKEY_CLASSES_ROOT\CLSID\{037C7B8A-151A-49E6-BAED-CC05FCB50328}
HKEY_CURRENT_USER\Software\75319611769193918898704537500611
Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu2\Programs\Antivirus 2009
Step 4 : Use Windows Command Prompt to Unregister Antivirus 2009 DLL Files
  1. To open the Windows Command Prompt, go to Start > Run > type cmd and then click the "OK" button.
  2. Type "cd" in order to change the current directory, press the "space" button, enter the full path to where you believe the Antivirus 2009 DLL file is located and press the "Enter" button on your keyboard. If you don't know where Antivirus 2009 DLL file is located, use the "dir" command to display the directory's contents.
  3. To unregister "Antivirus 2009" DLL file, type in the exact directory path + "regsvr32 /u" + [DLL_NAME] (for example, :C\Spyware-folder\> regsvr32 /u Antivirus 2009.dll) and press the "Enter" button. A message will pop up that says you successfully unregistered the file.
  4. Search and unregister "Antivirus 2009" DLL files:
%UserProfile%\Local Settings\Temporary Internet Files\Content.IE5\S96PZM7V\winsrc[1].dll
c:\WINDOWS\system32\winsrc.dll
Step 5 : Detect and Delete Other Antivirus 2009 Files
  1. To open the Windows Command Prompt, go to Start > Run > type cmd and then press the "OK" button.
  2. Type in "dir /A name_of_the_folder" (for example, C:\Spyware-folder), which will display the folder's content even the hidden files.
  3. To change directory, type in "cd name_of_the_folder".
  4. Once you have the file you're looking for type in "del name_of_the_file".
  5. To delete a file in folder, type in "del name_of_the_file".
  6. To delete the entire folder, type in "rmdir /S name_of_the_folder".
  7. Select the "Antivirus 2009" process and click on the "End Process" button to kill it.
  8. Remove the "Antivirus 2009" processes files:
ieexplorer32.exe-removed_skip
ieexplorer32.exe
%UserProfile%\Start Menu\Antivirus 2009\Antivirus 2009.lnk
%UserProfile%\Start Menu\Antivirus 2009\Uninstall Antivirus 2009.lnk
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\Antivirus 2009.lnk
%UserProfile%\Desktop\Antivirus 2009.lnk
c:\WINDOWS\system32\scui.cpl
Antivirus 2009.lnk
av2009[1].exe
AV2009Install.exe
Antivirus2009.exe
av2009.exe
Go here and download,install and run http://www.spywareremove.com/download/SpyHunter-Scanner100835p2s2.exe
  • 81 Answers
Visit this link  you will get all help
http://www.bleepingcomputer.com/malware-removal/uninstall-antivirus-2009
Posted on Mar 22, 2009
    Problem Solver:
  • 12 Answers
<a rel='nofollow' href="http://www.2-spyware.com/remove-antispyware-2009.html">Antispyware 2009 description and manual removal guide</a>
Posted on Feb 25, 2009
    Scholar:
  • 134 Answers
Info and instructions on how to remove Antivirus 2009 here : http://www.cas411.com/ShowArticle.aspx?ID=85
Alex
Posted on Feb 15, 2009
    Novelist:
  • 176 Answers
Reboot your computer into safe mode by repeatively tapping on F8 while you reboot. Once there do a system restore to an earlier date, run anti-spyware, anti-virus, clean out your internet temp files
Or you can go to this site and do a download this ani-hijack, anti-virus, anti-spyware, etc, etc;
http://www.paretologic.com/xoftspy/se/newlp/revenuewire/xray/
How do i get the security tool screen to quit coming up. and over riding programs that says i have viruses, and wants to sell me protection
The programs coming up that say you have viruses and want to sell you protection sound like the real problem here. Sounds like you have some spyware that is disguised as something like WinAntiVirus 2009, or AntiSpyware 2009, etc. These will constantly seem to scan and report multitude of false infections trying to get you to buy them. The real problem is the program itself, it is the spyware. I would start by going here first to check: http://www.surfright.nl/en/hitmanpro. Malwarebytes.org also has good antispyware checks.
Mar 02, 2010 | HP Computers & Internet
Ran a scan said nothing was found.Looked quarantine 2 Virus were quarantined. one was Win32/PSN.LineageDN/PWS-Lineage,the other one I did not get written down.I got online to try and find out what to do...
SPEAKING WITH MY EXPERIENCE UNISTALL IT. TRY SOMETHING ELSE.
FREE SPYWARE
Download Spybot Search & Destroy. Restart computer, then run Spybot to see what spyware comes up, AND DELET IT.
FYI---Virus Protection-- 2 programs of virus protection will conflict with each other and will actually cancel out the protection. SO just download one.
Running Spybot Search & Destroy with EITHER Avast or Avg (great Free virus protection programs ) will keep a computer in good working condition. FREE
HERE ARE SOME LINKS, THAT WOULD BE BETTER:
NEW *****Somthing new FROM MICROSOFT.*** 2009 ---Security Essentials
http://www.microsoft.com
*****Spybot - Search & Destroy 1.5.2 ****
FREE SPYWARE
http://www.download.com/Spybot-Search-De…
****Avast ***FREE ANTI VIRUS PROGRAM
http://www.avast.com/eng/home-registrati…
****AVG ****FREE SPYWARE PROGRAM
http://www.free.avg.com
**Ccleaner*** FREE
http://www.download.com/3120-20_4.html?q…
***Malware**** FREE
http://www.malwarebytes.org/.
$ *** KASPERSKY ***
http://www.kaspersky.com
There are alot of $ anti-virus and Internet security programs out there,
ie: Norton, McAfee, Panda, Bitdefender. If you would like to pay $ then get ***Kaspersky***-- 2010 , I feel that is the best for your money.
REMEMBER TO KEEP UP THE DAILY MAINTENANCE ON ALL OF YOUR COMPUTERS.!
Good Luck.
If you think this is good information, , please rate me.
Sep 24, 2009 | Webroot AntiVirus with AntiSpyware &...
Webroot won't load
SPEAKING WITH MY EXPERIENCE GET SOMETHING ELSE.
FREE SPYWARE
FREE SPYWARE
**Ccleaner*** FREE
***Malware**** FREE
$ *** KASPERSKY ***
Good Luck.
Sep 07, 2009 | Webroot AntiVirus with AntiSpyware &...
I installed norton antivirus 2009 with antispyware,nowi lost some files i keep getting a windows exeplorer error message then my start screen froze up also i cannot use my system restore
boot into safe mode then try restore or boot from your windows disc to repair previous installation. Don't use norton, resource hungry invasive software. plenty of good free ones like antivir
Aug 02, 2009 | Symantec Norton Antivirus 2009 1-User -...
Webroot antivirus will not update at all. June 20, 2009
If it is not a new bought program, then remove it.
Some useful information below. Hope it helps.
SPEAKING WITH MY EXPERIENCE TRY SOMETHING ELSE.
FREE SPYWARE
Pop up Blocker ** free******
www.panicware.com
FREE SPYWARE
**Ccleaner*** FREE
***Malware**** FREE
$ *** KASPERSKY ***
Good Luck.
Jun 20, 2009 | Webroot AntiVirus with AntiSpyware &...
All of a sudden pc gotinfected by trojan
Download Malware Bytes and do a scan and clean, it should remove MS Antispyware 2009.
Please post back here if you need additional help...
Apr 06, 2009 | Compaq Computers & Internet
MS AntiSpyware 2009 alert appears on my screen and as Icons/These have been identified by Norton 360 as a virus. How do remove?
Download Malwarebytes. Install it and run a full scan:
http://www.filehippo.com/download_malwarebytes_anti_malware/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 05, 2009 | HP Pavilion dv9000z Notebook
Virus MS AntiSpyware 2009
HI,
Your PC has been effected with spyware.You can try using a spyware software like webroot 2008 to remove this.
This is the only solution to fix this thing.
Dec 30, 2008 | Computers & Internet
I downloaded the program Antivirus 2009 Professional but i cannot access it or find a way to make sure it is installed
Antivirus 2009 is a hoax. It a virus/spyware intended only to harm your computer. To get it off is way hard. Check my website.
http://sites.google.com/site/turbospeedmycomputer/
Aug 22, 2008 | F-Secure Anti-virus Client Security...
Microsoft Windows XP Home Edition for PC Logo
440 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
