Sony DVD RW DW-31A stopped writing and not recognising CD in tray
Medion PC with Sony DVD RW DW-Q31A writer and DVD ROM DDU1615 internal drives.
Stopped in middle of burning music to same type/batch CD used just prior. Message asks for "Insert empty disc to write to. Medium in drive:Unknown. Medium required by compilation CD-R/RW" (which is type used.)
This followed by: "DRM: DRM burn session terminated" and "DRM: Closing entire DM handling. Bye." which I assume is where i "cancel" the burn process when it fails. Same thing each time attempted with Nero or Windows Media or itunes s/ware.
PC support said reinstall windows to factory setting and then reinstall all software. Must be easier solution to that. Any ideas please??
  • jimmy2fish Mar 14, 2009
    No, not doing a disc copy, just selected tracks already stored on hard drive from itunes to CD.
    President:
  • 1,223 Answers
Are u copying the disc on the fly i mean directly from dvd rom to dvd rw it sometimes generate this error when reading drive stops giving data due to some error and suddenly bcoz of that the writing drive leavve the session un closed and give an error the solution is first copy ur disc on the hard drive and then copy it on another disc on the fly copying is not safe otherwise also try this
pls try to clean the lens of the drive as follows
due to dusty environment and excessive use lens gets dusty and then have problems in reading or writing dvd 's and cd's
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens or cotton bud good quality see if it works , other wise ur DVD drive lens got weak from use now adays service centers are getting tons of them everyday for replacements
u can try that software thing as well but i dont think it will solve ur problem
pls do rate me FIXYA if i fixed what u wanted
Posted on Mar 11, 2009
  • Shoaib Rais
    Shoaib Rais Mar 14, 2009
    my friend u can always ask for more help b4 rating someone in appropriate , who has spend time to trouble shoot the problems u are facing free of charge , the error u provided comes when there is some hardware problem like weak lens or something or there is an issue in dvd drive hardware
    re installing the OS wont help u in this case , ur rating does not allow me to carry on further with u
    be courteous when getting help these ratings affect us
    regards
My two Sony DVD-Drives, DVD RW DW-Q31A and DVD-ROM DDU1615 doesn't work: They are disabled (Error-Code 32). The original Drivers are present.(Windows XP) I can't find newer Drivers. On another...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
May 05, 2011 | Computers & Internet
I have an external teac dv-28e-n usb DVD writer device which does not recognise and burn DVD rewritablce discs.
I think that Teac DV-28e Is a CD/DVD-ROM only, and will not burn discs. Teac DW-28e is a CD RW/ DVD ROM unit, and will thus play and burn CDs, but will only play DVDs. Check your model numbers to confirm, and then consider exchanging units if you need to burn CDs.
Dec 20, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
Teac Dw 224E-R WONT BURN ON A DVD - Is it a DVD Writer?
hi no its only a CD RW, and not a CD/DVD-RW its just a CD writer and a dvd( rom )..read only memory which means it only reads dvd's but does not write them...hope this helps
Jun 14, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
Trying to copy some pics onto a cd to get some disc space but my drive wont recognise the cd rw
do you have a cd writer or rom drive is the first thing you have to check, if it's a writer then put the disc in first and it should give you an option to write files to cd accept then follow the the instruction to add your files, assuming your running windows. iif that does'nt work check to see if your discs are + or - it may be your wriiter will only accept one kind
Mar 26, 2010 | Compaq Presario V4000 Notebook PC
Power Calibration error
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
CD/DVD Drive will not read cd cd/rw or dvd/rw's
Goto the web site of the company that makes the writer and reinstall or update the internal Firmware for that model of writer.
Jul 02, 2009 | Computers & Internet
Internal CD ROM will Not Open
Unless you can do electronic repair yourself and have the schematics for the drive it will be far cheaper and easier for you to simply replace it. Any DVD drive for computers will fit in there. I would buy a new one rather than used so you make sure and get the software with it. Replacing the drive is a 30 minute job at most.
Dec 31, 2008 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Computers & Internet Logo
    317 people viewed this question
    David Payne
    David Payne
