Question about Dishwashers
Dishwasher door spring
I have a Frigidaire dishwasher (model # FDR252RBB0|) and I need to replace the door springs.Where do I get the parts and how do I replace it? Are there instructions somewhere that I can follow.
Thx.
  • Anonymous Mar 21, 2014
    The door spring on my dishwasher is broken. How do I replace it.
    President:
  • 1,314 Answers
Remove the lower kickplate open the door hook the spring on the hooked part of the door and then in one of the holes in the frame youll see
Posted on Feb 11, 2009
THE LATCH IS READING THAT THE DOOR IS CLOSED BUT I CAN OPEN THE DOOR WHILE THE DISHWASHER IS IN CYCLE. WITH THE SPRING INDISE THE DOOR BEING LOCKED IT WONT EVENT LET ME FULLY SHUT THE DOOR! ANY HELP.
Hello friend, thank you for your post!
From what you have described the spring from the latch is broken inside of the door and you are unable to close your Frigidaire dishwasher. You would need to disassemble the dishwasher in order to replace the latch or spring. This needs to be done by a professional technician as improper disassembly could results in personal injury. I hope this information is helpful to you. -Matt
Feb 19, 2016 | Frigidaire Dishwashers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
How do I adjust the springs on the door of a Frigidaire dishwasher Model # FDB24?
Springs run down both sides of the dishwasher from the door hinge to the back leg area of the frame at the bottom leg area. You adjust the spring/door tension but moving the spring to different holes in the frame area. Going one direction in the holes will loosen the door, going the other direction will make the door tighter.
Mar 26, 2015 | Frigidaire Dishwashers
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
Door falls open, no restraints
Yes, I've fixed a few, and was unable to fix a few. You may need to remove the whole cover of the dishwasher to get to the insides. You should find either the springs are broken on both sides of the bottom of the door, or even more likely, the plastic parts between the springs and the body or the door have broken. The parts can be ordered from "Sears Parts" on the inter-net. You will need to provide the model number to look them up.
Be blessed.
May 21, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Have problem with door on Frigidaire Electolux dishwasher. Door "falls open" rather than eases open.
there is a spring that connects to the side of the door (both right and left) than connects to the holes on the bottom of the dishwasher frame. These springs have either fallen off or broken. To see the area where they connect you will need to remove the very bottom panels below the door. Look at the frame where the leg height adjustment screws are and you will see several holes in the frame the springs will most likely be right there and just need to be reconnected to the frame itself. If the springs are not there then the springs will more than likely be right at the bottom left and right side of the doors. These springs should be set in the 3rd hole back from the front if the door drop is still too fast set the spring further back on the frame.
Hope this helped
Dave
Feb 04, 2010 | Electrolux Frigidaire Professional Series...
I have a frigidaire quiet clean I dishwasher model # MDB124BFS2 - the spring on the door has broken. How do I replace it?
Hi, The easiest way would be to pull the d/w washer out of the cabinet about 8". Try removing the kick plate below the door and see if you can access the springs ok. Here is the part # 154430501. I would replace both springs while you are in there.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
The door on my dishwasher will not close
There are a few problems that can occur with the diswasher door assembly. These usually involve the latching mechanism, the door seal, the counterbalance spring assembly or the hinges. 1) The door latch plate can occasionally become out of alignment. Some door latch plates are adjustable, some aren't. If yours is adjustable, try loosening the retaining screws and repositioning the plate. It's trial-and-error, so have a lot of patience. If this doesn't work, then the latch needs replacing.
2) A new dishwasher or a newly installed door seal can be difficult to close for a while until the seal softens and compresses over time. You can try adjusting the latch, if possible.
3) If the door feels unusually heavy, there could be a problem with the counterbalance spring assembly. These counterbalance assemblies allow the door to open and close easier and are held by two springs. On some dishwasher models, holes are positioned in line so you can re-tension the springs by moving the spring hooks to other tensioning holes. If any of these springs break, they will need to be replaced as a pair.
4) The door hinges might be bent. They can seldom be adequately fixed and should be replaced.
hope this helps
Nov 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
I need to replace the Door Springs
if you just need to install springs pull the bottom kickplate can do it there only two screws
Dec 29, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
543 people viewed this question
Top Dishwashers Experts
