Question about Pantech Matrix Cell Phone
My screen is loose on my Matrix and it flops out and around. HELP
Ok, so i might have a small problem of sliding my phone up and down and left and right but now the screen broke. It flops open and slides down, any minute it might fall off of it. I've had this phone for almost 5 months and up until now i loved it. I dont want to buy another phone but its been more than three days. What should i do??
I had the same issue with a pantech duo that the sliding part to display the keyboard broke... att replaced mine.
Posted on Feb 16, 2009
How do I connect my Matrix m1 mobile phone to the internet?
How to Use the Pantech Matrix for the Internet1.Press the "Menu" key on your Pantech Matrix and click "Settings.
2.Click "Connections" and highlight "Modem Link." Press the "OK" key. Turn the modem link settings to "Inactive." Press the "End" key to exit to the phone's standby screen. 3.Download and install ActiveSync on your computer if the operating system is Windows XP. If you have a later version, download and install Windows Mobile Device Center. Follow the on-screen prompts to properly set up the program. 4. Press the "Menu" key on the Matrix and click "Settings." Scroll down to "Connection" and press the "OK" key. Click "USB" to "PC." 5. Open ActiveSync or Windows Mobile Device Center. Click "Device Settings." Click "Internet Sharing" under the "Programs" tab of the program. 6.Select "USB" from the drop-down menu under "PC Connection." Select "AT&T" from the "Network Connection" drop-down menu. 7.Click "Connect" and connect the Matrix to the computer using a USB cable. A status message of "Connected" will appear in the program's window when the connection is established.
Jul 21, 2011 | Pantech Matrix Cell Phone
How to multiply matrix on fx-991ES calculator?
hi..
Its very easy to do matrix operations in FX 991ES
This calculator can operate up to three Matrices at a time, namely Matrix A (Mat A), Matrix B (MAT B), Matrix C(MAT C).
  1. First to do, is set the calculator in MATRIX Mode
    Its Easy
    Press MODE button and press 6.
    Your Display will show indication of MAT on upper side of screen to show now calculator is in MATRIX Mode
  2. Now we need to Define matrices and set its dimensions.
    This product supports matrix of order up to 3x3. That is you can operate matrix of No. of rows=3 and No. of columns=3
    To input matrix, Press SHIFT and then 4. This will Pop up Menu for Matrix. Now press 1
    Your screen will show as this,
    MAT A will be your First Matrix and MAT B will be your Second Matrix and so on.
    Press 1 , 2 , or 3 to select Matrix A , B, or C.
    here I will Proceed with Matrix A, so I press Numerical 1 Key
  3. Next screen will ask you about the size of matrix.
    Press UP or DOWN Keys to view options.
    Press Corresponding Numerical keys to select corresponding order.
  4. On Next Screen , enter values on each positions
    Press UP, DOWN, LEFT, RIGHT Keys to move around in matrix and specify each element.
  5. Now we inputed Details about Matrix A. If you want to specify other matrices (MATRIX B, MATRIX C) repeat STEPS 2 To STEP 4
  6. After Specifying required Matrices, we can tell calculator to do operations with them.
    Press SHIFT and then 4 and then It will show a menu contains
  7. For example, i need to multiply Matrix A with Matrix B, i'll enter as
    SHIFT + 4 + 3 to Input Matrix A
    X
    to enter operator (Here multiplication, You enter + - x / for corresponding arithmetic operations )
    SHIFT + 4 + 4 to Input Matrix B
    = To show Result
    Press UP DOWN LEFT RIGHT Keys to view extra fields, if any.
Hope this will help you.
have a good time with Casio FX 991ES
Mar 26, 2011 | Computers & Internet
Ok my pantech matrix was working fine but the screen is stuck on white. the key pads light up and everything. is there any way i can fix it so i dont have to buy a new phone?
Hi this is a very common problem with all flip and slide phones and even laptops and notebooks, the problem is to do with the data ribbon that connects the screen to the circuit board in the bottom of the phone.
now inside this ribbon are several single strand copper wires and over time open and closing the phone causes these to break and you then lose the connection with the screen.
as this is such a common fault it makes the part itself cheap to buy and cheap to get fitted. it isnt something you can do your self as you need specialist tools to take the phone apart and to fit the data ribbon.
if you want it repaired the cheapest place would be one of those small independent phone shops as the bigger one will have to send it off and you will be charged extra for this, the smaller phone shop should be able to fix it whilst you wait or the next day at the latest.
its up to you if you think the phone is worth getting fixed then it wont cost much to get done.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 19, 2010 | Pantech Matrix Cell Phone
Pantech MATRIX C740 slide hinge has come loose. How do you take the phone apart to fix? (Pantech Matrix and Duo are not the same phone)
i suggest not taking the phone apart. 5 of my friends and myself have the matrix and after flipping it a couple of times the hinges are always going to feel loose. they have felt that way on mine for over a year. and if you take it apart, the senor bars for the keyboard will go out and you will have to get a new phone or just use the number pad
Jan 10, 2010 | Pantech Matrix Cell Phone
GHW9250ML0 - belt off, pulley misalignment, bearing ok
no pulley should have that much clearance or movement....Something is seriously worn. Perform surgery and find out what failed.
you will have poor performance until you get this issue resolved and tighten the belt correctly.
Sep 25, 2009 | Washing Machines
My matrix the front part is falling off
that needs to be reparied by the company or just have to deal with it nothing anyof us can do...sorry
Jan 07, 2009 | Pantech Matrix Cell Phone
Side kick 3 flip up screen flops around
if you have had the phone for less than a year T-mobile will give you a new phone.
Jan 04, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My pantech matrix screen does not want to switch when i try to use the texting part. what can i do to fix it. i have taken the battery out and reset it
ok this happened to me too bc my friend was sliding it and being dump. The duo amd matrix have a really good spring when you slide the phone up, but they couldnt find a place for a second spring when you want the qwerty keyboard for the duo so they put a OK spring there for the matrix. It has nothing to do with the battery or settings. If you have insurance go to at&t and tell them the problem, but if you dont (CAUTION) you can try wiggling a knife in there. If you bought it in the last 30 days you can go and tell them and they will give you a new one.
Hope I helped
Dec 27, 2008 | Pantech Matrix Cell Phone
My screen is black on my LG shine the phone still works, but the screen is competely black can I get a new LCD screen for this slider phone? what can I do
Is it a flip flop type of phone or a slide type.?
You need to eplace the flex wire of that phone 'coz that's the
usual problem of all flip and slide type of phones
Mar 18, 2008 | Lands Phones
Pantech Matrix  Cell Phone Logo
81 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
