Question about Clarion (VRX765VD) Car DVD Player
Installed Clarion VRX765VD, has power but no sound...
I have a '04 Sebring Limited with the 7spkr Infinity sound. I purchased the Metra 70-1818 harness that is needed to connect the Clarion to the car. For the most part i was able to connect the wires for the black/grey attachments, so the unit powers and functions. My problem is that i am not getting any sound at all. The wiring harness that i bought has 4 RCA male hook-ups (Grey, White, Purple, Green). The Clarion has similar colors corresponding but the with two females. To make things even more confusing, the Clarion on the oppisite end has more wires with the same color scheme, only those would require splicing. Can anyone provide any advice?
  • searcygayboy Feb 15, 2009
    You have to connect the grounding wire from the HU and connect it to the grounding wire that was previously attached to the rear of the OEM radio. This will tell the Infinity amp under the passenger seat to turn on
SOURCE: Faceplate
I lost my faceplate for my radio I looked for it for 2 month and the way I found it was at ebay.com
they sell the remote too I payed $65.00 for them both .Good luck!
Posted on Nov 04, 2008
insanegtp
  • 112 Answers
SOURCE: DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Posted on Jan 26, 2009
Ruff_Racer
  • 49 Answers
SOURCE: park brake switch
If you have the old firmware then all you need to do is ground the parking brake wire..
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Posted on Jun 29, 2009
style_points
  • 34 Answers
SOURCE: I just install new Clarion BTL370 in the Clarion
A few things to check...
Make sure the receiver is set to "tel sw" or something similar in the menu. From there, you should be able to set the call to the left or right speaker. Make sure you set the headset to the same side.
Another thing to check, make a call and get connected through the headset. Now wait a few seconds and push a button on the phone to power the backlight. If it is wired correctly, you should see the "connected" timer on your phone keep time. If it appears that you are connected, the problem is most likely in the settings.
Also, if nothing else works, make sure that you have the accessory wire(should be red on the BLT370) connected to the right wires. All the other wires will power it on even if this wire is not connected correctly.
Posted on Jul 27, 2009
emissionwiz
  • 79847 Answers
SOURCE: UNLOCK CODE REGION FOR CLARION VRX765VD
these codes are hacked into by persons more savoy than me, I have gone to the blog sites where they exchange the info about "region hacks" as they call it, no hack exists yet for your paticuliar DVD player, check back in a few months for an update, will be glad to keep looking..
Posted on Sep 01, 2009
How do i hook up the dvd player for a Clarion
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
orange/white illumination
brown phone interrupt
grass green park brake connect this to earth if u want to watch dvd whilst driving
pls rate
Jul 08, 2010 | Clarion (VRX765VD) Car DVD Player
Sep 01, 2009 | Clarion (VRX765VD) Car DVD Player
What do the color codes represent on the outputs on a Clarion VRX765VD?
Hello davetk76,
Here's the color code for the RCA outputs: Gray - front; Black - rear; Violet - non-fader (subwoofer); Green - 2-Zone; and single gray with yellow plug - video out.
If you do not have the manual, I'd recommend that you go here to Crutchfield and download a PDF copy. Save it to your computer and print out pages 72-73 which has all of the wiring.
Hope this helps.
May 25, 2009 | Clarion Car Audio & Video
Raiderz1985@hotmail.com
Malfuxion@gmail.com Has the same dam problem with my 2000 chevy suburban
Apr 26, 2009 | Clarion (VRX765VD) Car DVD Player
Faceplate
Sep 09, 2008 | Clarion (VRX765VD) Car DVD Player
Factory Amp
I assume you used the correct Metra plug (70-1878) to install the radio. Ensure the blue and white wire on the Metra is attached to the blue and white wire (or solid blue) on the Sony. This will provide + turn on voltage to the factory amp.
The other good possibility is that the Metra harness has a black and a black and white set of wires both must be ground.
Lastly the Metra harness does not provide these( -) grounds, they are supplied by the braided strap . or the single wire that was attached to the back of the Jeep radio.
Jul 22, 2008 | Infinity 475A Car Audio Amplifier
Clarion vrx765vd will not power on.
What about the power you tapped into in the car? Maybe a fuse blown there?
Feb 28, 2008 | Clarion (VRX765VD) Car DVD Player
VRX765VD Manual
http://www.manualnguide.com/download/manual-guide/clarion-vrx765vd-product-manual.html
there ya go
Jan 22, 2008 | Clarion (VRX765VD) Car DVD Player
Car Audio & Video Logo
205 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
