Question about Konica Minolta magicolor 2400 Laser Printer
Streaks and faded spots
Have ben getting streaks on one side of printer as well as faded spots on other side
I had the same problem. Your printer might be in 'envelope' mode. open the top of the printer and look towards the back. You should see two grey tabs with envelope symbols on them. make sure they're pushed down.
Try that
Posted on Feb 09, 2009
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
Faded streaks for only blak color on Ricoh 3500N laser printer
Your toner cartridge is probably getting low. Toner is actually a powder, and it can get settled during shipments, bringing it home, etc etc. Take out the black toner and give it a gentle side-to-side shake a few times and pop it back in.
That should help.
Apr 28, 2010 | Ricoh Aficio CL3500N Laser Printer
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
After approx 1-2mins the screen fades to black and white streaks and spots
LCD is going bad and eventually it won't show any image. LCD is not able to regulate the voltage going into it so to much is going into the LCD and thats why the spots and streaks are showing up.
Nov 28, 2009 | Toshiba Satellite 5105-S501 Notebook
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Black streaks down left side of printouts Epson Aculaser C2600
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Dec 02, 2008 | Office Equipment & Supplies
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Two dots on right side of page
if you replaced the cartridge and the streaks are still there then it's the fuser. you can try to clean the "fuser" roller with a little alcohol and your finger nail (after it's cooled down) to scratch off the toner, if it's an actual scratch on the roller you need to replace the fuser as it will pickup toner again and leave marks.
hope this helps
thanks for rating
Jan 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
184 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
