Question about Toshiba Satellite M105-S3004 Notebook
Toshiba my safe won't open
Toshiba my safe folder won't open
  • Mr fix.it May 11, 2010
    what is the path of the my safe folder. pleas also tell me what operating system you have on the laptop so that I can help you further.
Laptop opens with a big distorted picture and won't open
hmm try this
turn off computer
press F8 for safe mode and hold down while restarting computer
tell me if that same condition repeats
return for second phase of solution
Jun 01, 2012 | Toshiba Computers & Internet
I'm using a Toshiba Satellite L655. Whenever I
open control panel
mouse icon
check settings
if all ok there then it might be that mouse drivers kaput reload from website or disc
May 24, 2012 | Toshiba Computers & Internet
How do I get my toshiba satellite L505 to stop starting up in safe mode?
Let it start in safe mode, Once it boots up click Start/Programs/ and look for the RUN prompt. It might be under the Accessories folder. Once you get RUN to open type msconfig and press OK.
When the System Configuration window opens Click on the "Boot.ini" tab at the top and make sure the /SAFEBOOT option is not selected. If it is, remove the check mark then hit OK. Reboot and see if it goes to normal.
Apr 27, 2012 | Computers & Internet
Hi! I've got a Toshiba Satellite L300 and it won't boot anymore. I get past the initial toshiba-screen where I can press F2 and F12 but afterwards there's just a black screen with a little...
You can retrieve your data by removing the hard drive and connecting it to an USB hard drive adapter then plug it into the USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and files to back up your data.
You can then return the hard drive back into the Toshiba then format the hard drive and reinstall Windows to get your Toshiba working again.
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Jul 05, 2011 | Toshiba Satellite Pro L300 Notebook
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
I have forgot the password for my Toshiba NB 520
Hi melvasey,
If you forgot your password for your Toshiba laptop you can do system restore inside Safe Mode.Kindly follow the steps below to help you address the issue:
1. As soon as you turn on the computer, keep on tapping the F8 button.
2. Once you already have the boot menu, select Safe Mode or Safe mode with Networking.
3. If you're able to login inside Safe Mode. You can do System Restore. Here's how:
  • Go to Start then, Accessories.
  • You need to select the System Tools folder.
  • Inside the folder choose System Restore.
  • System Restore window will open, click on Next.
  • You need to check on Show more restore points, so you can have different options to choose from.
  • Select your desired restore point. Take note to choose one where you are able to use your computer. Then hit on next and wait until the process is done.
  • Finally, your computer will automatically reboot.
Hope it helps.
Thank you for using Fixya.
Mar 27, 2011 | Toshiba Computers & Internet
Toshiba hard drive says its on the safety remove but will not show up on computer folder
look for the drive name(for example: e: f: g: etc... ) in safely remove hard drive...
goto start > run > in the run box type the name of the drive...
for example : in the run box just type f:
it will open the f: drive...
alternatively you can open the run box in vista and win7 by pressing ( windows key + r )... it will open run box...
Dec 12, 2010 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
I cannot remove a folder on my desktop
This is happening because you just copied the folder over from the other user. The system thinks that you do not have the right to delete is cause it is registered under that user. (which is gone now). The only think I can think of is to log in as an administrator under safe mode and try deleting it that way then rebooting. Tap the F8 key on boot up to access safe mode options.
Please do not forget to rate me.
Feb 02, 2009 | Toshiba Satellite M45-S351 Notebook
Toshiba Satellite M105-S3004 Notebook Logo
406 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
