My TV is fuzzy
Whenever I turn my Tv on it tends to get very fuzzy to the point that I have to change the brightness in it I wondering if someone could Please help me ?
  • Televison & ... Master
  • 1,689 Answers
Most of this type of fault is caused by a defect in the high voltage section, CRT bias supply, or the CRT itself. In a more complex situation there may be some problems in the video processing sections.
In the case of an LCD TV a common cause are, the backplane lamps and or the backplane power supply, and or the main power supply may be failing.
Jerry G.
Posted on Jan 31, 2009
  • 118 Answers
I can help by saying go to the menu of it and look up "search for channels" If that doesn't help then it's just your cable connection.
Mitsubishi TV Model TS-4557 Two problems: 1) The picture is very dark despite the brightness control being at the maximum. 2) The picture is fuzzy - particularly when there is text on the screen, to the...
the problem is picture tube base which connects picture tube to circuit board ..inside ur tv..take tecnical help of service men to replace the p.t.base
Mar 13, 2010 | Mitsubishi TS-4557 45" TV
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
Fuzzy Rear Screen Projection TV
Probably the EHT unit is failing or the Focus Control is out of adjustment or if it gets worse as the brightness increases, may need a new TV.
Apr 02, 2017 | Televison & Video
Tv too bright
This problem might be caused by a problem called blooming. is the picture fuzzy and does the picture look to be streched out. Since you do not have contrast and brightness control this would almost completly point to the HV section of the TV either the control and screen grids of the CRT are going bad or the HV power supply is about to go bad, I would suggest that if you have a background in electronics that you check the HV at the anode of the picture tube and make sure the voltage is from 20Kv to 40Kv using a high voltage probe. You will need a schematic to aid you in your troubleshooting
Nov 07, 2007 | Apex Digital AT2008S 20" TV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Tv F27442
The TV does not have a reset button. If you have no picture and no sound, there is something wrong with the chassis. In this case the set should be serviced by someone experienced in the RCA CTC203 chassis. If you have no picture but do have sound, then it is possible that the 2 controls in the 2 little holes in the back of the set are not adjusted correctly. This is quite possible since you said you put a screwdriver in there and got a fuzzy picture. The control on the bottom is called "screen" and is the overall brightness of the picture and the control on top is called "focus" and is the sharpness of the picture.
May 20, 2007 | RCA F27442 27" TV
Fuzzy white lines
YOUR tv DEVELOP a problem in the video ocillator or the tunner section have this set check by a qualified solve your problem good luck.any more contact i hope by now you have gotten your set fixed the repairs will cost you about between $ $200.00 good luck.
Feb 25, 2007 | Sharp 32U-S60 32" TV
Televison & Video Logo
453 people viewed this question
Top Televison & Video Experts
