Sharp AR-5320 Black and White Copier
Problem for Sharp AR-5320 Black and White Copier
Password to avoid the unauthorized Use
By asif_menmud on Jan 31, 2009
SIr, I have the SHARP AR 5320E photocopier.
How can i set the password to avoid the unauthorised users.
thanks in advance...
Clarification Request
Posted by toniruku on Nov 10, 2009
Go to user mode ie press and hold light key until two dashes displays, enter 11 and press print key, --- will display , put you desired number eg 123 and press print key then press light key once to store your desired password. For more information , refer to user's manual on user programs.
Solution #1
posted on Aug 05, 2009
Not Rated)
russel23
Rank: Wiz  Sharp Expert
Rating: 79%, 15 votes
press the exposure light button for 5 sec n after that the indications wiil apear n on the display there will b 2 dashes blinking so u input 10 n press stars after that the no wiil blink 100 so u have to make 101 by pressing start then press c n then input 11 start n when 3 dashes blink input ur code only 3 digit n press start n press the expossure botton n cm out if there is any prblm call me on 9923483607
Comments:
Aug 29, 2009
- refer the manual
Oct 26, 2009
- u can refer to the user manual n ull get evrything onthat
Was this helpful?
Yes
No
Solution #2
posted on Mar 23, 2009
Not Rated)
SALIH OBAID
Rank: Guide
Rating: 85%, 4 votes
press the light exp key for more than 5 sconds the tonet and jam leds wil plink
press 10 then print the screen will give 100 the last 0 is blinking write 1 then press print
press c
press11 then print
the screen will give you ---
write your passward (three digits)
press print
press light exp
now you have apassword
enter it to use the copier
when finished logout by pressing cc#
Was this helpful?
Yes
No
Popular Solutions for Sharp AR-5320 Black and White
Questions and Unsolved Problems for Sharp AR-5320 Black and White
Do you recommend Sharp AR-5320 Black and White Copier?
Answer
Answer
Canon IR 3200, when i make a copy in full color mode the copy has a shadow or not clear, when i make... (More)
Answer
sharp arm350-450 the imagistics versions adjusting of the printer void area lead & trail edge... (More)
Answer
powersuply sharp ar-5320 14c471
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AR-5320 Black and White...:
Top Copier Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
