Question about Magix Audio Cleaning Lab 2005 for PC
BURNING CD USING MAGIX SEQUOIA,NO CDR DRIVE FOUND!
WHEN I ATTEMPT TO BURN A CD THE PROGRAM TELLS ME THAT, NO CDR DRIVE IS FOUND! CAN SOMEONE HELP?
  • Anonymous May 16, 2009
    MAGIX AUDIO CLEANING 15. I CAN USE OTHER PROGRAMMES TO BURN MY MUSIC BUT NOT MAGIX 15, IT TELLS ME THERE IS NO CDR FOUND
2 Suggested Answers
ghouliass
  • 105 Answers
SOURCE: Moving MAGIX files to a different computer.
If magix support .iso files do an iso image of the cd you plan to burn
you'll have then a 600-700mb iso file that you have to burn at work.
of course at work your recording program should support ISO's, or you will obtain the same unusable file as you get back from your home
Posted on Nov 21, 2008
enothor
  • 36 Answers
SOURCE: I have installed Music studio deluxe 2004 on
First you need to find out if your CD-R is showing up in device manager correctly and is displayed in My Computer, if not then you need to uninstall and reinstall it and also make sure that your program is compatible with Windows 7.
Posted on Nov 06, 2009
I want to burn a cdr on my windows 8 computer, ive tried to use itunes but it keeps telling me that my disc isnt blank, however i changed the format and it is blank,help?
the issue is with the cd burning software that you are using and the format you want to use it in. you need the correct software installed in the computer, nero or cyberlink can help.
this could also be a case of driver corruption or infections where the system is not able to recognize the cd correctly.
if this does not help, then call 1-877-805-1027 for expert help
Aug 06, 2015 | Apple iTunes
I am trying to burn a CD. The playist has 15 songs, 1 hour and 101 MB. I am burning to a CD with 700 MB and 80 minutes of space. iTunes says there isn't enough room on the CD. So, I click to go ahead...
Your CDR is 700MB and you have 101MB of data to burn, isn't it obvious that you have overloaded your data by 31MB for burning? The CDR will not burn in your case. Reduce your intended data to less than 700MB and the CDR will burn.
Oct 19, 2010 | Apple iTunes
How do you burn a movie file using roxio easy cd & dvd burning. i cannot get anything to work
ONE: This program installs a rootkit I believe, although it's a really great program otherwise, especially nice for beginners. Do you have a virus checker that kills rootkits? If so you may have to enable permission for that program to run in your virus checker. If you don't know how to do that, try step 2.
TWO:
Uninstall the program.
Turn off or unplug your modem to protect your computer from viruses.
Shut down your virus checker.
Install Roxio again and then try running it with your virus checking program still shut off.
Try burning a CD. Does it work fine?
THREE:
Turn your anti-virus program back on again.
If a message comes up asking if you want to give the program
full access,
limited access,
or block it, tell it you want to give it limited access. (That will allow it only access to safe operations. If you block it, your program won't work).
FOUR:
If it still won't burn, make sure you have a blank DVD or CD in the correct drive that the program wants to burn to, (or else change the drive it wants to burn to if you have more than one) and that it has no data, scratches or fingerprints on it.
May 12, 2010 | Roxio Easy CD & DVD Burning
I have installed Music studio deluxe 2004 on windows 7 and I can't burn a CD it says No CDR found
Nov 06, 2009 | Magix Music Studio deLuxe 2004...
IS THIS SOFTWARE SUITABLE FOR USE WITH SONY DVD RW
Yes it certainly should be compatible with the CD/DVD drive.
Roxio has it's own burning software included with the program, you will just have to explore the software until you work out how to burn a CD using Roxio itself.
If you want to try another burning program try Nero 9 trial. All you have to do is enter your email address and then download the software. Nero is an excellent bit of software, i personally have never had any problems with it.
Get Nero 9 here >>>>>>>>>>
http://www.nero.com/eng/downloads-nero9-trial.php
Regards.
Sep 29, 2009 | Roxio Easy Media Creator 7
After starting studio 12 deluxe., the program asks for the initial disk to be put into the drive, even althogh it is still there. It won't do anything else. How do I fix it?
Hi sweeneyr95
Try to look on these solutions:
1.Some programs have more cd´s for the installation, maybe it is another cd you need to insert ??.
2.Maybe it is the cd that is corrupted (scratches and similar) maybe you can save the cd with this program (Unstoppable Copier):
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Unstoppable-Copier.shtml
3. There can bee need to get the Support Team of Magix :
http://support.magix.net/magix_relaunch/php/page.php?page=request
4. Your cd/ dvd player is not working. Try to insert another cd and see if it can read the contents.
Hope this will help
Have a nice weekend
Please rate my answer
Sep 12, 2009 | Magix Music Maker 12 Deluxe
How can I burn a CD or DVD of a "movie" I made with photos and music? I am using Microsoft Picture It Express 9. Any help would be great!
Hi!
Firs of all you need to think on in what format you having that movie in. I guess you want to play it in a ordinary dvd and and they are restricted, all dvds plays mpeg bur not all plays dvix,xvid etc
When you have decided the format you need a burning program, one of the best is Nero ( http://www.nero.co ) its not free but you can download and try it for 30 days.
Another program is cdburner ( http://www.cdburnerxp.se/ ), that oen is free, not as good as nero in my opinion..but..its free
After installing the burner program you need to select if you need a cd or a dvd disk to burn on, a cd takes 700mb, there are cd:s that takes 800mb but they are more expensive. A dvd takes 4,7gb.
Now its time to burn, start the program select the disk you going to burn on, then its just to drag and drop the moviefile you want to burn. When the movie file is in place, start burning, select the burning speed, dont burn to fast since you burning a movie, i recoemnd a speed of 15-20x speed
After burning, your done! take out the disk ans enjoy your movie!
Let me know how it goes
Good luck
Nic
PS, i asume that you have a cd/dvd burner on your pc
Mar 30, 2009 | Microsoft Picture It! Photo Premium 9.0...
Nov 21, 2008 | Magix Audio Cleaning Lab 2005 for PC
Program Crashing
hi dear
please try to render be a file first, after that you can burn it with nero burning rom
oke
cropp
Feb 27, 2008 | Ulead VideoStudio 9
Magix Audio Cleaning Lab 2005 for PC Logo
633 people viewed this question
Top Magix Graphics Publishing, Design & Multimedia Software Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Magix Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
