Question about Compaq Armada M700 Notebook
Armada m700 display problem
There is a display on the lcd during POST but after that the screen is all but black, if i press caps lock and num lock there is a response from the computer.
How do i get to the recovery partion on compaq armada m700
Dear Lizanne,
To get to the recovery partition on your Compaq Armada M700, turn on the notebook and press F11 repeatedly until "Windows is loading files..." displays on the screen. Then, follow the on-screen instructions.
If your notebook originally came with Windows XP or an earlier version of Windows, try pressing F10 to enter recovery instead of F11.
Hope you may find these instructions useful!
Best regards,
Miguel L. Martins
May 16, 2014 | Compaq Armada M700 Notebook
LCD Monitor isn't recognized
it is an issue with the LCD on your laptop as you get a fine display on external monitor
either get it repaired from a local technician
or get the LCD replaced
Jun 07, 2008 | Compaq Armada M700 Notebook
How to get to boot chooer on tne m700 starts
Hi.
  1. Turn on the computer. When the Compaq logo displays, press F10. Or,
  2. During Power On Self Test (POST), and after the memory check completes, press F10 as soon as you see a small white square flashing on the top right corner of the screen.
  3. In the computer setup, use the right arrow to move the selection to the Advanced menu.
  4. Use the down arrow to move the selection down to Boot options, and press Enter. The Boot options menu pops up with four boot order options.
  5. Use the down arrow to move the selection.
  6. Press the left arrow to change the order of Notebook.
  7. Press F10 to accept the change.
  8. Press ESC to jump back File menu, and then move the selection down to "Save changes and exit".
  9. Press Enter. If asked to save changes and exit, press F10.
On some laptops you can change the boot order by tapping the F12 key as the computer starts up.
Regards.
Jul 16, 2011 | Compaq Armada M700 Notebook
I have a Compaq Armada M700 and the top part the display screen falls back - it no longer stays upright or at an angle.
on the m700 i think you can tighten the hinge........
if not i could always send you hinges......
cheers
Apr 07, 2011 | Compaq Armada M700 Notebook
"HP Pavilion m7580" is not
To verify whether it's a no POST issue, press NUM LOCK or CAPS LOCK key and check whether the CAPS LOCK or NUM LOCK lights are lit or changes when you press on it. If it doesn't then it's a No POST problem.
However, if the computer screen shows the HP logo or a display then it's POSTING and is experiencing a No BOOT issue.
If the NUM LOCK or CAPS LOCK responds when you press it but there is no display, check the connection between the monitor and the CHASSIS or CPU.
If you have verified that it's a No POST issue because CAPS lock is not responding, you need to open up the chassis to do a troubleshooting procedure. Be sure to unplug the chassis to all the connections especially the power cord. Drain the power by pressing and holding the power button from 8-10 seconds.
Here are the things that you need to do after you open up the chassis.
1. Reset the Memory sticks. Connect the CHassis to the power and monitor. If no go, try turning on the computer without the memory sticks. The aim of this troubleshooting is to see a display on the screen. Any display would be a good sign. If no go. Put the memory stick back in.
2. Remove the CD drive. Turn on the computer, check for development. If no go, proceed to step 3. Just leave the cd drive removed
3. Do the same thing with the other devices like the hard drive and other devices inside. Your aim is to see a display.
Let me know if what happens and I'll get back to you.
Once you see a display. Let me know by replying to this thread.
Apr 07, 2011 | HP Pavilion m7580n PC Desktop
When i press power button then no display on lcd/white screen
1) When you power on ur pc?? do you get any display in beginning or when windows starts ti gones black.
2)If no display from the beginning??? try pressing caps or num lock key and see whether led on keyboards are blinks or not?
3)Do you get any beep sound when you try to power on??
Sep 09, 2010 | Acer Computers & Internet
Writing why the Left is the number keys, u, i, o, j, k, l
if you hold the FN key and press 'num lock' this can hold those keys as numbers, press FN and 'num lock' together again to disable it and turn them into letters again.
Nov 02, 2009 | Compaq Armada M700 Notebook
Compaq armada m700 display problem
Try and toogle your FN key or connect an external monitor and toggle on FN key
let me know what happens....
Jan 31, 2009 | Compaq Armada M700 Notebook
My Screen Is Black When I turn the Laptop On
need a inverter maybe. t23 lcd inverter check ebay diy project need a screw driver thats it
Apr 14, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Compaq Armada M300 Loose Display Screen
There is no adjustment on the m300 v300 m700 v700. These hinges will have to be replaced. I do have a set from an v300 am not sure if they are compatible but you can have them if you want.
Mar 18, 2008 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Compaq Armada M700 Notebook Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
