My USB ports don't work
I have six USB ports on my desktop computer, none of them work. I plug in my flash drive or webcam and it says that the computer reads it, says it's ready to use and then comes up with USB device not recognized and that the device attached to the computer has malfunctioned.
I use WIndowsXP Home Edition and I have ASRock 775Twins-HDTV motherboard.
The USB ports have not been working for three weeks now, all I want to do is use my webcam!
  • luke_allen_8 Feb 01, 2009
    How do I re-install the motherboard chipset?
  • Anonymous Apr 26, 2009
    The ports on my computer are no longer working...someone please help. thanks
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 141 Answers
Good day,,
your usb port has the problem.. try to follow this steps:
1. Try to check if the usb bus is installed, to do this right click on my computer
2. Click manage
3. Click Device manager
4. On the right side click on the plus sign of the universal serial bus controller
5. Check if all the item is in correct
if you are done and then the problem is still the same,try this one
1. Re-install your motherboard chipset
2. Ensure to install and try to look if the computer install the usb serial bus controller
tanx..
Posted on Jan 31, 2009
  • Computer Repair Services
    Please use the CD that was with your system unit when you last buy it. Their is a package CD installer when you buy it right? So that's it try to install that one
How do i get my computer to recognize my usb flash drive
If your device drivers are up to date, the USB ports are totally recognized. If the USB device plugged into the port is not initialized, it may not be recognized by the computer operating system. If a USB flash drive was working and no longer works; it could have been damaged when removed from the computer when last used. Flash drives are sensitive to Static Charge. Like when you rub the feet on a carpet and a spark of electricity jumps from a finger to another person. You must use the Eject method when removing Flash Drives.
Feb 10, 2018 | Computers & Internet
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
I have a logitech flash drive that is not picked up by my computer when I slot it into the USB port - I went to my computer and checked under disk management but it is not even coming up under there - do I...
Hi.
USB flashdrives are usually all plug and play so you don't need any additional drivers for them.
Try plugging the flash drive into a different computer. If it works on another computer your USB slots maybe faulty.
If the flash drive is not picked up by another computer then the flash drive is probably faulty.
Regards.
Jun 07, 2011 | Computers & Internet
Icon won't appear on desktop.
It is possible that your USB flash drive is dead.
The other solution is to try it on some other USB port of your PC (if you used front panel USB ports now try it on the back panel).
If it also wont work, try to connect it to some other PC
If it works with an other PC, your USB ports are dead
You can try going to device manager, and to unintall USBs and reinstalling them
Nov 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have 3 usb ports( two at the back and one on the
Check to see if something else will work on the side port. It may not necessarily be a dead port. Just something you should know too; I used to work for Wal-Mart in the electronics department and they had to recall all their firefly flash drives because they had a tendancy to malfunction. Try using it on a different computer, it might just be a dead flash drive. I hope this helps your problem and I hope your flash drive didn't have anything too important on it :x
Oct 15, 2009 | Computers & Internet
Flash drive not working
An option that you could do is to plug the flash drive in the back of the computer. The reason is because flash drives derive power from the USB port itself unlike other usb devices that you are using may have their own power or because the USB port in front does not give as much power as the one from the back.
Jan 10, 2009 | Computers & Internet
Running XP pro on a Compaq Presario Desktop AMD. Two USB ports on front of unit worked prior to reinstalling OS . Afterwards plugging in a flash drive that worked previously... Computer will Sometimes...
Check to see if the back ports behave the same way with the flash drive, If so then it appears to be a software issue. If not...look closely at the pins inside the ports and make sure none are bent. If attempting to straighten pins be sure to power system off first. Also check inside the case to see that the front USB connectors are secure. Also
Nov 28, 2008 | Computers & Internet
The flash drive purchased doesnot work when pjugged into the usb port on my desk top but it work on my lap top? How do I get it to work on my desk top
Hello claponte
FIRST, THE HARDWARE SIDE:
If you just purchased your flash drive, then it is using the USB 2.0 (high speed) standard. Prior to that were USB version 1.1 and, before that, USB 1.0 standards.
USB 2.0 devices will still work when plugged into USB 1.1 ports - just at a reduced speed)
However, computers w/ USB 1.0 ports cannot properly detect USB 2.0 devices. On those computers, you'd need to install a USB 2.0 expansion card in order to add USB 2.0 functionality to the computer.
SECOND, THE SOFTWARE (DRIVERS) SIDE:
On the software side, USB devices are "plug-and-play" on Windows XP & Vista systems. This means they do not require special drivers or installation for them to work properly. The drivers needed for them to operate are already built into the operating system.
However on operating systems prior to Windows XP (Windows ME, Windows 98SE, Windows 98...) drivers are needed for USB devices to be detected properly.
These are two possible reasons why your flash drives don't work on your desktop computer.
(01) The computer is an older one using USB 1.0 technology
(02) The operating system is pre-Windows XP
Another possibility is (if your computer USB ports are at least 1.1 standard and your operating system is at least Windows XP) there is an issue w/ the USB ports on your desktop computer. This could be a hardware or a software issue still.
Please, let us know if that's the case and we'll help you to trouble-shoot the issue.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Computers & Internet Logo
617 people viewed this question
David Payne
David Payne
